SOURCE: lg lcd tv remote code
HI,
BUY A NEW REMOTE FROM E-BAY OR PARTSTORE.COM,TRY A UNIVERSAL ONE IF STILL DOESN'T WORK TV INTERNAL IR INTERNAL RECEIVER IS FAULTY,THANKS.
SOURCE: Programming remote for Zenith DVB412 DVD Player
Here is the response from LG/Zenith customer support:
Unfortunately, this remote has very limited programmability. The manual is correct.
INSTRUCTIONS: Controlling other TVs with the remote You can control the sound level, input source, and power switch of non-LG TVs as well. If your TV is listed in the table below, set the appropriate manufacturer code.
Code numbers of controllable TVs
If more than one code number is listed, try entering them one at a time until you find the one that works with your TV.
Manufacturer Code Number
LG/GoldStar 1 (Default), 2
Zenith 1, 3, 4
Samsung 6, 7
Sony 8, 9
Hitachi 4
For further information or troubleshooting, you may contact us at 800-243-0000 for LG Customer Service assistance. An agent will be glad to assist you. Please feel free to contact us with any additional questions or concerns. Thank you again for contacting LG Electronics.
SOURCE: programming my remote
http://66.77.167.109/rcaaccessories/BrandCode.do
go here for your codes to any rca remote
SOURCE: Need programming instructions for RCA RCR4383
Quick answer:
(TV) Citizen............1004, 1013, 1035, 1046, 1061, 1078, 1103, 1123, 1126, 1127, 1133
Note: The actual manual doesn't provide the codes, but can help you assist in programming the code into your remote.
Resource used:
http://www.rcaaccessories.com/rcaaccessories/RcaaccessoriesInfo.do?findManual=RCR4383
Manual(direct pdf link):
http://audiovox2.info/docs/rca_acc/man/RCR4383_DOC_OM.PDF
Code List(direct pdf link):
http://audiovox2.info/docs/rca_acc/man/RCR4383_DOC_OTHER.PDF
replace with new batteries and it works --- so simple
Here's what to do. I've had this happen many times.
1. Open up the SD Card compartment on the Wii.
2. Open up the battery cover on the remotes.
3. Press the red Sync button on the Wii, and then on one of the remotes.
4. Repeat for whatever remotes need synced.
This will make every remote act like the P1 remote. For temporary syncing, just go into the Home Menu and click Wii Remote Settings. Click on another option(it'll say to press 1 and 2) and follow the instructions.
