20 Most Recent Nintendo Wii Remote Controller Questions & Answers
2answers
I have tried syncing my remote and the wii and the
you need a wii remote charger from energizer you canbuy it at gamestop
12/29/2022 10:17:17 PM • Nintendo Wii... • Answered on Dec 29, 2022
2answers
Controller & two player mode problem whit Wii Sport Resort
I had this problem and it was down to be, me plugging the motion plus into the wrong controller.
I have one control with intergrated motion plus and the other uses a plug on motion plus. I accidently plugged the plug on one into the already intergrated control leaving the one control with nothing. Hence that control could not be recognised.
Hope this helps
5/27/2020 12:03:40 AM • Nintendo Wii... • Answered on May 27, 2020
My Wii remote won't turn on. Yes the batteries
Hmm, if it's not the batteries, it is most absolutely the Wii Remote. Is your Wii Remote in any way damaged physically or technologically?
10/24/2017 10:42:47 AM • Nintendo Wii... • Answered on Oct 24, 2017
Wii remote is not charging. I
If you have had the "battery" for a long time, it could be that it can no longer carry a charge. Rechargeable batteries' charge grow shorter over time. If you still use the Wii/Wii U regularly, I suggest rechargeable AA batteries+charger (If you don't have them already). AA batteries work in other devices so even if you stop using the Wii, the batteries will still work in remote controls, clocks, flashlights etc unlike a WiiMote Battery pack.
9/15/2017 1:03:04 AM • Nintendo Wii... • Answered on Sep 15, 2017
Wii fix guide
Try this link it may help. If not there may be an issue with the console or controllers. Try the controllers on a different wii. Try a different controller with your wii. Wii Remote Not Working or Syncing Correctly Wii and Wii mini Nintendo...
10/12/2015 1:19:05 AM • Nintendo Wii... • Answered on Oct 12, 2015
I washed my wii remote and i m trying to get on my wii what do I do
Well...The only real solutions you've got are to buy yourself a new Wii remote or attempt a salvage technique. Really old one, at that. Take a bag (Or bowl) of white rice, lay the remote inside of the rice, and then cover it with plastic. Leave it overnight. The rice will actually suck the moisture out from the remote, and possibly fix the problem.
2/22/2015 5:22:00 AM • Nintendo Wii... • Answered on Feb 22, 2015
My new wii control only blinks
There is a little red button on the front of the wii by the sd card port. Open the door and push it. Now on the back of the wii controller in the battery compartment there is a red button push it. Now your controller and wii will sync. you could also push the 1&2 buttons at the same time after you push the red button on the front of the wii.
12/18/2014 9:32:39 PM • Nintendo Wii... • Answered on Dec 18, 2014
HOW TO MAKE YOUR WII REMOTE WORK
Place new batteries in your Wii controller, if using rechargeable packs may have to replace as wear and tear runs the lifetime down
9/4/2014 11:40:00 PM • Nintendo Wii... • Answered on Sep 04, 2014
I can't seem to sync my wii controller. All 4
    Try these steps!
  1. Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet.
  2. Turn the power of the Wii console ON. When you see the Health and Safety screen, open the small flap on the front of the Wii console to find a red button labeled "SYNC." Press and hold the SYNC Button down for 15 seconds. This will clear all the syncs on the Wii, allowing you to get a clean start to begin the process described below.
  3. After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes:
    1. With the first Wii Remote you wish to sync, remove the battery cover on the back of the Wii Remote to find a small red button just below the batteries.
    2. Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink.
    3. Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture).
    4. When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
    5. This sync procedure (steps "a" through "d" above) must be followed for each additional Wii Remote added to the system.
if nothing else works call 1-800-255-3700
5/5/2014 3:24:21 AM • Nintendo Wii... • Answered on May 05, 2014
Wii Remote wont sync with the Wii
open the battery door on the remote, theres a red button. also there is a red button on the wii in the SD card slot press the one on the Wii then the one on the Remote.
1/28/2014 12:55:11 AM • Nintendo Wii... • Answered on Jan 28, 2014
My wii remote wont turn on
How old is the battery? They won't last more that 2 years.
1/13/2014 11:02:14 AM • Nintendo Wii... • Answered on Jan 13, 2014
Wii remote doesn't turn on
You might need to change out the batteries.
11/28/2013 4:50:17 PM • Nintendo Wii... • Answered on Nov 28, 2013
Post battery change- Wii remote won't sync
you will have to reset the consuleback to new you do that buy going in to the menu and setting follow the directions its because the software know what its looking for
11/28/2013 4:47:37 PM • Nintendo Wii... • Answered on Nov 28, 2013
I can't sinc my remotes to my wii
Try unplugging the Wii then plugging it in and press the red button on the wii then press the red button on the remote until lights flash then press the red button on the wii...hope it helps
10/12/2013 4:37:26 PM • Nintendo Wii... • Answered on Oct 12, 2013
My wii remote control managed to find its way into
Try putting it in a bowl of rice for 4-7 days. Rice dries out the water from electronics and then put in new batteries. Hope this helps
9/13/2013 1:45:50 AM • Nintendo Wii... • Answered on Sep 13, 2013
My wii remote got wet. can i fix it?
Have you tried putting it in a bowl of rice for a week or so? I haven't experience this myself but if a Wii remote is anything like an iPhone it should dry out all the water. Putting new batteries in it after the bowl of rice would be a good idea too. I hope this helps
9/13/2013 1:43:04 AM • Nintendo Wii... • Answered on Sep 13, 2013
Nintendo Wii Remote Controller Logo
249 questions posted
Popular Products
Top Nintendo Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Aron
Sean Wright
Sean Wright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
View Most Popular
  • Nintendo Video Game Consoles & Games
Most Popular Question
39 t seem sync wii controller all 4
  • Video Game Consoles & Games
