SOURCE: Kenmore 110.96588210 Electric Dryer
you can take the top panel back off and check the start button with omes meter,push button in you should get a reading,let button out no reading ,if it fails the test replace,let me know what you find
SOURCE: Dryer keeps running and timer continues to move around dial.
Change your timer. It has a malfunction in it. it's about a 100 dollar fix. Also your start switch may be bad.
SOURCE: Dryer runs when door shuts. Only stops when door is open
There is a safety switch in the door that shuts dryer off when door is open. If there is more to your problem let me know. From what you have stated there is no problem.
SOURCE: Kenmore Electric Dryer Model 110-C62662101.
Problem with the timer control unit as it is not switching off until reset with the door latch.
it is possible that the dryer control relay or driver is short and giving power continuously.
SOURCE: I have an LG dryer. Can the door be switched (like a refrigerator) to open from the other side?
Most can. Check on the opposing side and see if there are any mounting holes. You may have to remove a panel in order to expose them.
The image below shows the wiring diagram for your model of dryer. The door switch is shown in the closed position. When the door is opened, the contact is broken that completes the neutral circuit through the door switch. (I am not showing that your model of dryer has a drum light. If it did, then the drum light would illuminate when the door is opened.)
Based on your symptom, a bad door switch is apparently causing this problem. It is not breaking the neutral circuit to stop the motor from running. Replacing the door switch assembly should fix this problem. NOTE: Be sure to unplug the dryer before accessing any internal components.
