JustAnswerhttps://www.justanswer.com > Appliance Repair
Dec 23, 2009 - Just open the door, remove all the screws around the door panel and control panel going around the inner door liner. Remove the 2 screws going ... 1 answer · Top answer: very easy. Just open the door, remove all the screws around the door panel an
Asko dishwasher reset How to Reset an Asko Dishwasher
Press the "Start/Stop" button.
Hold the button for three seconds and release.
Select the program and options on the front panel you want the dishwasher to use. Press "Start/Stop" to restart the dishwasher. You have now reset an Asko dishwasher.
Hi- Yes, you need replace the entire dispenser. Viking dishwashers are actually Askos on the inside. It's not too hard to replace if you are handy and can get the part from Viking directly. Unplug the unit or shut off the breaker and remove the front panel by removing the screws around the outside edge of the door. I believe the dispenser is held on with brackets (it's been awhile since i replaced one on an Asko or Viking). It should be pretty evident how to remove it once you have it opened up. If you are unsure at all call Viking and they can give you the number of a Tech. Good luck.
Hi mike,
thanks for the clarification. Having this info, I am not sure this model is as the post indicates - "1595". Is it possibly a 1473 or 1474 model with a power button by the door handle ? If so, that is the most common problem with that style Asko. The contacts inside the button make momentary contact & then stop which requires replacing tge switch. Let me know if it is indeed one of these models or confirm what model number it is ok ?
Thanks,
Macmarkus
Go to page 9 of the manual and it shows you the steps to take when your dishwasher has stopped draining. Its the section that says "Dishwasher does not drain properly".
You may have to check your dishwasher filters for clogs and if you get that far in the troubleshooting process, it shows you on page 6 & 7 how to check those filters for clogs.
