Electric Mobility Shoprider Electric Power Wheelchairs Scooters Trooper Logo
HARVEY A GROSE Posted on Jan 23, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Shop rider deluxe wont go forward or reverse - Electric Mobility Shoprider Electric Power Wheelchairs Scooters Trooper
Rob Hill
Level 3:
  • Electric Mob... Master 1,480 Answers
  • Posted on Jan 31, 2024
Rob Hill
Level 3:
Answers
1480
Questions
0
Helped
518191
Points
3838
Hi does the brake click at the rear when moving the wigwag lever ? .
Can you check the brushes in the motor ? resistance of the motor should appear as virtual short , the brake resistance should read from 25ohms upto 80ohms, the scooter won't drive if the resistances are wrong .. the controller could be faulty , and i offer a free testing service if you're UK based
here's a trouble shooting manual for shopriders ..
https://www.gewizrepairs.co.uk/shoprider_service_manual.pdf
Regards
Rob
The bike will go in reverse but won't go forward. how do I fix this?
Lil' Rider FX 3 Wheel Battery Powered Bike, Black - Amazon ...
www.amazon.com/Lil-Rider-Wheel-Battery-Powered/...
Amazon.com, Inc.Amazon.com: Lil' Rider FX 3 Wheel Battery Powered Bike, Black: Toys & Games. ...On Motorcycle 6V Toy Battery Powered Electric 3 Wheel Power Bicyle, Red ... VTechGo! ... sound effects, working chrome colored headlight, and forward and reverse ...power wheels vehicle more to handle size, weight, and your child won't ...
Lil' Rider FX 3 Wheel Battery Powered Bike, Blue - Amazon ...
Amazon.com, Inc.Amazon.com: Lil' Rider FX 3 Wheel Battery Powered Bike, Blue: Toys & Games. ...Sold by: Global Supplies (We currently can't ship to, HI, AK,APO,FPO, POB) .... Ride On Motorcycle 6V Toy Battery Powered Electric 3 Wheel Power Bicyle, Red ... sound effects, working chrome colored headlight, and forward and reverse ...
KB901 Lil' Rider FX 3 Wheel Battery Powered Bike ...
? 8:05
https://www.youtube.com/watch?v=fED8N8DTQfU
Oct 21, 2013 - Uploaded by TMKGL
My car wont reverse in revrse wants to go forward in neutral allso
Check the linkages between gear shift and Box could be loose. If these are OK get a transmission service by a good Auto Transmission shop
Why is my shop rider deluxe not working proper with new battery's
Is the high low speed switch turned to high. If it is and its still slow it would indicate a throttle pot fault
My Husqvarna Rider 16c wont reverse - first it was slow in reverse then not at all
You need to check the cable, it is a push pull telescopic style so it is possible to get forward and no reverse, if it was a hydro problem you would not get forward or reverse, there is also timing gears on the forward and reverse pedal, you nee to make sure they have not jumped a tooth as this would reduce movement on the cable at the hydro
1helpful
My alero with a 2.4 cylinder wont go forward but go in reverse
You have a failed transmission, have it taken to a transmission shop for repair.
Rider will not move when in gear, forward or reverse
If it has an external brake on the side of the transmission, make sure this is not binding, you can check this by putting the machine in bypass ( push mode ) you should be able to push the machine readily, if not the brake needs slackening off.
May 12, 2012 • Garden
3helpful
How do i charge my shop rider derlux
Shop-riders come with a off board battery charger.
It will plug into the top of the tiller ,where the three holes are.
Go to this link it has a copy of the Manuel it helps out alto and tells you what type of charger you need for your scooter only.
Hope I was of Good help.
Shop rider mobility vehicl, forward speed less than reverse speed
Hi. The black boxes on these machines are quite reliable. Where are you measuring the voltage from?
How are you testing the batteries? I have seen fully charged batteries do this, because the batteries are not able to supply enough current. The batteries will charge up properly, but they ready for the scrap heap. If you want the batteries tested take them to your nearest auto electrical store and they can test them. Good luck. Neil.
Too slow how do I speed it up , a Pihsiang shop rider delux
hi, have you tried another charger as this sometimes can lead to batteries not 100% fully charged , I think the scooter in question is 6mph , check battery leads are a good connection and make sure the speed variable pot on the control panel is working correctly , is the speed pot working correctly (Wig wam) , try moving the lever in a upwards motion while moving forward , does it speed up ? if so it needs replacing.
Regards
GeWiz.
Top Electric Mobility Health & Beauty Experts
Rob Hill
Rob Hill
ZJ Limited
ZJ Limited
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
