Dear Sir,
*********** board is Asus old p4 Mother board.It supports maximum 1GB RAM of DDR 400(DDR1). According to your post your computer having only one 512 MB working RAM. If you want good purformance you can upgrade your computer by purchasing another 512MB DDR400 RAM and install it on another RAM slot.If your computer have only one working RAM slot,you can purchase 1GB DDR400 RAM & install it on older RAM place. I think it solves your problem.if you have any problem come back with more information. I will try to assist you more accurately.
good luck
Q: Will my system recognize the maximum upgrade?
A: Possibly
How much memory your Windows OS will recognize depends on which version of Windows you are running. 32-bit versions of Windows will see (and utilize) only 3GB or 3.5GB. To utilize more memory, install a 64-bit version of your OS. More information about OS memory maximums can be found at http://www.crucial.com/kb/answer.aspx?qid=4251.
Q: What memory goes into my computer, and will a faster speed be backward-compatible?
A: DDR memory with support for DDR PC2700,DDR PC3200 speeds.
Because DDR memory is backward-compatible, you can safely upgrade your system with any of the guaranteed-compatible DDR speeds listed below, even if your manual calls for PC1600 or PC2100 speeds.
Q: How much memory can my computer handle?
A: 3072MB.
Adding the maximum amount of memory will improve performance and help extend the useful life of your system as you run increasingly demanding software applications in the future.
Q: Do I have to install matching pairs?
A: No.
No, you can install modules one at a time, and you can mix different densities of modules in your computer. But if your computer supports dual-channel memory configurations, you should install in identical pairs (preferably in kits) for optimal performance.
A: No.
Your system does not support ECC. Because ECC and non-ECC modules should not be mixed within a system, install the same type of modules that are already in your system.
512MB
256MB
function updatePartList(event)
if ($('hidAllToggleNames')&& window.location!=null)
var queryParam = window.location.search;
var paramArray = queryParam.toQueryParams();
var pt =paramArray['pt'];
if (pt == 'SSD')
var allToggle = $F('hidAllToggleNames');
if (allToggle.indexOf('pftDIGITALMEDIA' ) > 0)
$('hidProdTypeToggle').value ='pftDIGITALMEDIA';
$('hidProdTypeSelected').value = 'DIGITAL MEDIA';
if ($('divRecParts'))
$('divRecParts').style.display = 'none';
toggleProdType($F('hidProdTypeToggle'),$F('hidProdTypeSelected'));
updatePartListData();
function hideAll()
var allText= $F('hidAllToggleNames');
var i = 0;
var arrText = new Array();
arrText = allText.split(',');
for (i = 0; i 0)
new Ajax.Updater
{success: 'partList'},
$F('fil_filePath') +'ajax/_partList.aspx',
method: 'get',
parameters: params,
onFailure: reportError
$('filterProgress').style.display = 'none';
function toggleProdType(prodTypeToggle, prodTypeSelected)
var prevProdType = $('hidProdTypeToggle').value;
hideAll();
$(prodTypeToggle).style.display ='';
if (prevProdType != prodTypeToggle)
$('hidProdTypeToggle').value = prodTypeToggle;
$('hidProdTypeSelected').value = prodTypeSelected;
/*var prevProdType = $('hidProdTypeToggle').value;
Effect.toggle(prevProdType, 'blind');
Effect.toggle(prodTypeToggle, 'blind');
function reportError(request)
alert('Sorry. There was an error.');
function rssURL(newURL)
var params = GetParams();
var feedURL = $F('hidRSSURL') + '&' + params;
if (feedURL.length > 0 && newURL.length > 0)
if (newURL == '{0}')
newURL =feedURL;
else
newURL =newURL.replace('{0}',escape(feedURL));
window.location = newURL;
return true;
function GetParams()
var noOfForms = document.forms.length;
var noOfFields;
var fieldName;
var filterSuffix = $('hidProdTypeToggle').value;
var prefix;
prefix = 'filter' + filterSuffix + '|';
var modelName = escape($F('fil_model_name'));
var prodTypeName = escape($F('hidProdTypeSelected'));
//for some reson encode of + is not done.
modelName = modelName.replace('+','%2B');
modelName = modelName.replace('%B5','%u00b5');
var params = 'model=' + modelName +'&file_path=' +escape($F('fil_filePath'));
for (var i = 0; i
We're now showing 4 of 6 compatible upgrades show allDDR upgrades
US $42.99
Memory Module is DDR1 compatible Motherboard. You can add Memory at least 1GB or 2GB only.
Buy 1GB DDR1 Memory PC400 or any at least DDR1...
