20 Most Recent
ASUS motherboard P5S-MX SE LGA775 SiS671FX Dual core / Core2 Duo PCI-E integrated VGA micro ATX P5... (4719543152454) Questions & Answers
Audio driver for windows xp
Have you tried downloading the driver from ASUS site? www.asus.comIf you cant find the driver, install and register to DriverMax. It will select the rght driver for you.thanx
Display Card Driver
Want to make sure your drivers are in place and no errors have occurred? Simply click start right click on my computer select properties then select device manager scroll to Display Adapters and click on the small "+" you should see the model of your PCI Express graphic card there. If there is a problem with it, a yellow exclamation mark should appear besides it. If you don't see it everything is OK and your card is working properly.
If your computer came with a motherboard disc the drivers could be on it
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question exclamation mark ? mark ! or a red x right click select reinstall drivers
If your computer came with a motherboard disk the drivers could be on it
if you don't have a disk with the drivers you have to download them
Vga driver asuss
commonly VGA onboard driver always packages together with motherboard driver.. try to use device manager on control panel. when u see question mark on VGA driver, insert motherboard driver, right click on VGA driver at device manager. choose update driver, just choose recommended option and click next. your VGA driver will automatically installed. but if u still get trouble try to visit this site:
http://www.asus.com/Motherboards/Intel_Socket_775/P5SMX_SE/
1. choose download tab, then select your operating system.
2. choose what driver that u need, then there will be list of the driver.
3. click download button, there is some option, just choose one.
i hope this helpful. regard, riyan
No sounds
if your computer came with
a motherboard disc the sound drivers could be on it
click start control panel
administrive tools computer management device manager scroll to sound,video and
game controllers you might see a yellow question exclamation mark? ! or a red X
Right click to reinstall drivers
sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers)))
also audio you will find 3 drop down lists make sure you have the correct
settings there
also
sounds and audio devices select advanced there might be a tick in the mute box
untick it
if his does not fix the
problem
sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place
icon in taskbar for any further volume control settings you will need to right
click on the volume icon system select
adjust volume
click start control panel sounds and
audio,volume,advanced,speakers select the appropriate speakers from the drop
down list or navigate to the device manager scroll to system devices + to
expand,system speaker right click properties then select use this device
(enable) also you might check
the speakers plug/outlet is
usually at the back of the computer you will have to open up the computer
to check the lead attached to the rear of the input plug make sure the
connection is good
try cleaning your computer of dust using a fine air blower from a
compressor making VERY sure that there is no MOISTURE in the air line
specifically around the sound card and the CPU central processing unit dust
causes static to build up in a computer hope this helps
KEYBOARD NOT DETECTED
try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
dust causes static which causes lots of problems with a computer and its parts
or if this does not fix the problem
Click start control panel keyboard you can change your settings there
or you might have uninstall the keyboard then restart your computer then reinstall it and its drivers
click start control panel keyboard hardware then properties you hould see driver details and have options to,update driver,roll back driver,uninstall
click start control panel administrive tools computer management device manager scroll to keyboard you might see a yellow question mark ? right click update driver
if your computer came with a motherboard disc the drivers could be on it
diconnect the keyboard then reconnect it then reinstall the driver
make sure the lead has a secure seating if applicable or the usb device
hope this helps
