SOURCE: Sharp BA2100 3 CD mini component system - NO DISC
This is a relatively common problem when the optics get dirty. If you can reach the lens, try cleaning it using a cotton swab and alcohol. Don't bother with the "cleaning discs" available as all they can do is bruch off the dust. These lenses sometimes get a smoke or dirt film on them that the brushes can not celan.
Keep us posted.
Dan
SOURCE: Need User Guide/Owners Manual For:
Hi providing you 2 websites where you can download the required information.
www.fieldcommunicator.com/downloads/375UserManual.pdf
www.p4c.philips.com/files/3/37pfl9603d_10/37pfl9603d_10_dfu_eng.pdf
SOURCE: Sharp XL-HP515 CD Player won't play. Displays "toc read"
take it apart and clean len with a qtip an rubbing achol on face and mirror sides(top and under
SOURCE: Sharp CD-BA200 MIni Component Stero System
I've been messing with mine because it says no disc and I messed it up so it started saying this error. Unscrew the screws around the top (4 screws) and slide off the top cover. The small black rectangular box that sits over the eye/laser can be removed carefully by compressing the clips. Then the cd tray can be removed. I figured out this error was coming up because I had the tray out of alignment... so try to see if that's the problem with yours... also the eye itself slides (the entire mechanism it's on... slides away from and towards the place where the cd sits to be lifted and read) and it should be as close as possible to the area that lifts the cd. Sorry if this isn't making sense... trying to explain in the best way possible. The tray being out of alignment causes that error though.
SOURCE: I need a remote for a Sharp CD-XP3300 mini
~$11 delivered Buy It Now...
http://cgi.ebay.com/Sharp-RRMCG0318AWSA-Audio-System-Remote-/220507621157?pt=LH_DefaultDomain_0&hash=item3357474725
or $30+ here
http://remotes.com/remotes/servlet/rs?v=1&o=c&o=c&a=Search&uid=0&m=CD-XP3300&uuid=A12970320795941
