Try this site. https://printcopy.info/?l=en&mod=erc&brand=Ricoh
SOURCE: Ricoh Aficio MP C1500SP - functional error SC202
call ricoh serviceman he/she can fix it.
Defective tank full sensor
• Tank full lever bent or broken
• Incorrect ink suction
1. Check the harness of the tank full sensor.
2. Replace the GJ engine.
3. Replace the maintenance unit.
• The position of the tank full lever
does not stay at the tank full position
after ink initialization or air releasing.
• The position of the tank full lever is
not detected at ink suction.
SOURCE: RICOH 2015 error code sc 500
Main motor/ transport motor lock/ fusting motor error.
The only thing you can do is check for any obstructions in the machine.
That needs to be looked at by a service because the problem could be a motor, a pcb, or a power supply.
It can be a lot of troubleshooting to do.
SOURCE: Sir, My copier model RICOH MP
sc 302 - charge roller current leak. strip the drum unit (dmu) and clean the unit
Testimonial: "Sir, Thank you so much for your help, let me try in my copier and revert back once the problem is solved. Thanks Gopalkrishna T N"
SOURCE: Problem with the Ricoh mp c2800 Ricoh error code
If the model ia a MPC 2800 it a controller board issue maybe the operation panel. -carl
SOURCE: Error SC 551 / Ricoh
Hello!
This code is related to a Fusing temperature error.
You probably need to take a look at the heating roller thermistor.
The best advise i can give you is to call a technician to see it (if you do not have technical knowledge)
If you want to reset the code try this:
Press yellow key
Press in the key pad 107
Press red key at least 5 sec.
Press "copy SP"
On the key pas press 5810 and #.
On the touch panel press "execute"
Exit all the way out.
Turn the machine off and on.
Hope this helps you
