Televison & Video Logo
W
Walter Cieslinski Posted on Jan 16, 2019
I have a Sceptre X325BV TV Does replacing the board correct the problem?
I have a Sceptre 55 inch tv. Tv turns on for spit second and then no screen or sound. Done some research and replaced the power supply, my tv isn’t working still. What else could it be?
Some other board in the TV is drawing more power or isn't functioning at all. Use a voltmeter to be positive the power supply board is sending the correct voltages to the other boards.
Hi, have 2 sceptre 32 inch led tv, both same problem, no picture no sound, just red to blue light. do you have part that can fix this problem model, #x322bv and x325bv
I can't find a manual for either of these sets so I'm not able to be specific with parts but a set with no sound or picture is generally caused by either a bad main board or power supply. You can find out what board is bad by checking the PSON..stands for power switch on , the voltage should change when you push the on button and stay that way but going by the fact you get a blue light I'm guessing that is working and you have a bad power supply, another test would be with the set on and the light blue test the various power supply voltages and see if any are missing or incorrect, the values should be on the legends next to the connectors, they will say for example pin 1 ground pin 2...12 volts...pin 3... ground...pin 4.5 6...5 volts ect....Good luck!!
My tv does not turn on
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Are sceptre x505bv-fmdr and x505bv-fmqr circuit boards interchangeable?
Sceptre X505BV IR Sensor Board Please Read The Note ...
www.ebay.com > ... > TV Boards, Parts & Components eBayThey are not interchangeable. ... Sceptre X505BV IR Sensor Board - Please Read the Note C2050C .... $6.89 Buy It Now or Best offer Free shipping; Sceptre X505BV-FMQRIR Sensor Board $6.89 ... Sceptre X505BV-FMDR, IR. ..... For Samsung Galaxy Note II,; Cell Phone Printed Circuit Board For Samsung Galaxy Note ...
Sceptre X505BV All in One IR Sensor Board 142011100011 ...
eBaySceptre X505BV All In One IR Sensor Board - 142011100011 - Please Read the Note in ... offer Free shipping; Sceptre X505BV-FMDR IR Sensor Board 142011100011 ...Sceptre X505BV-FMQR IR Sensor Board. ... They are not interchangeable. .... PrintedCircuit Board for Galaxy Note 3,; Printed Circuit Board for Samsung ...
Why does my sceptre x325BV-FHD shows a red light indicating power is supplied when i plug it in but when i turn it on a solid blue light appears but i get no picture at all just the same blank screen
Main board fault. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Sound/Picture Flickering
Check its main power supply regulator board. The fault is there. Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
Top Sceptre Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
