20 Most Recent Sceptre 32 X320BVHD 32 LCD TV Questions & Answers
2answers
Need codes for ge remote to make a sceptre tv work
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience. http://remotesearch.blogspot.com/ http://electrohelponline.blogspot.com/
10/23/2022 2:13:17 AM • Sceptre 32... • Answered on Oct 23, 2022
2answers
SCEPTRE X322BV, HDTV BLUE LED COMES ON WHEN POWERING UP, BUT NO PICTURE OR SOUND
I have the X322BV-HD and with no warning had the same thing happen. I"ve scoured the net and found very little--just as here on this site. I just got off the phone with a tech support rep at sceptor and got the following information: HOW TO DO A FACTORY RESET:
  1. (Tech said this will often work even though you won't see anything on the screen--as long as the blue light is still on!) On the remote, press [MENU] and then 3 - 6 - 9 - 8 (If it's accepted, the TV will turn itself off.)
  2. Wait 10 seconds.
  3. Turn the TV back on and it will be back to all factory defaults.
That didn't work for me. But the second option, a Power Cycle Reset did. POWER CYCLE RESET:
  1. Unplug the power cord and wait 10-15 minutes (extremely important, I used a timer set for 16 minutes just to be sure).
  2. While it is still unplugged, press and hold the [POWER] button for at LEAST 30 SECONDS - DO NOT RELEASE!
  3. While continuing to hold the [POWER] button, plug the TV back in.
The second option worked for me and it's back on working just fine. Hope this helps!
2/24/2016 11:11:21 PM • Sceptre 32... • Answered on Feb 24, 2016
When turned on works until its get warm, thin goes off.
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electro-medical.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
1/7/2016 9:26:14 PM • Sceptre 32... • Answered on Jan 07, 2016
After running for a few minutes the picture abruptly shuts off and turns back on for a few minutes then shuts off. This cycle repeats itself over and over.
Make sure the top and back of it are not dirty or obstructed, it sounds like it is overheating and shutting down to protect itself. Or your main power board is going out.
11/29/2015 6:34:10 AM • Sceptre 32... • Answered on Nov 29, 2015
How do I have power but no picture or sound
The internal power supply inside your tv is defective.
10/2/2015 1:12:08 AM • Sceptre 32... • Answered on Oct 02, 2015
0answers
Why does my tv shuts off soon after its turned on?
The Sceptre is a fine TV but is very sensitive to power surges. If the unit turns off, soon after powering on, it is most likely the power supply. Try disconnecting the power to the unit for 20 minutes and allow to completely cool down. Re-connect the power and try the unit. Hope it works for you
5/23/2014 6:21:33 AM • Sceptre 32... • Answered on May 23, 2014
2answers
Tv is on with no picture or sound, only 4 months old!!
HelloThe power supply regulator board to your set has the fault. If you try to open the set, or try to repair it by yourself, the warranty will void. The set must have warranty as it is new. Why do you spend for it? Just contact the nearest authorised service center for Sceptre. the components in this set will be very hard to get from open electronic spare part market, and will costly too.
5/4/2014 5:09:33 PM • Sceptre 32... • Answered on May 04, 2014
Tv keeps shutting off
Main board fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. http://electronicshelponline.blogspot.com/ Pull up older posts.
3/31/2014 3:44:46 AM • Sceptre 32... • Answered on Mar 31, 2014
Tv will turn on but after about 20 minutes or so the screen goes black with thin colored bars running up and down the screen so i turn it off turn it back on and it does the same thing
Could be the tcon or main brd. The t con may not be available. Probably replacing tv would be cheaper that fixing.
3/19/2014 10:30:09 PM • Sceptre 32... • Answered on Mar 19, 2014
I have picture no sound tried headphones still no sound. what else can I do
Audio output section circuit to your TV should be checked. It will be best to replace the audio output board, as card basis, rather than trying to make any 'surgery' on it. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. http://electronicshelponline.blogspot.com/
3/16/2014 7:06:42 AM • Sceptre 32... • Answered on Mar 16, 2014
Over a week ago I sent my 32in sceptre back. It
You have to ask about this to the authorized service center for Sceptre. If the set is under warranty period, either thy should repair it and send back to your, or must give you an other TV of the same model. Why should you wait for? google.com/+GopakumarGopalan
11/2/2013 10:45:38 AM • Sceptre 32... • Answered on Nov 02, 2013
The sound comes on but display is black
Check and replace the back-light inverter board. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
10/28/2013 6:31:55 PM • Sceptre 32... • Answered on Oct 28, 2013
Sceptre Model X320 Display not working but sound
Check the backlight inverter.
10/28/2013 12:38:08 PM • Sceptre 32... • Answered on Oct 28, 2013
0answers
Sceptre 32 X320BVHD 32 LCD TV Logo
76 questions posted
Top Sceptre Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sceptre Televison & Video
Most Popular Question
sceptre x322bv hdtv blue led comes when
  • Televison & Video
