Toshiba 46G310U LCD TV Logo
Karl Zimmerman Posted on Jan 15, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Toshiba TV model 46G310U has a white light behind the screen. Tried to reset to factory settings didn't help.
timoboon2
Level 2:
Sergeant:
  • Toshiba Expert 360 Answers
  • Posted on Jan 16, 2019
timoboon2
Toshiba Expert
Level 2:
Sergeant:
Answers
360
Questions
0
Helped
154737
Points
959
Https://support.toshiba.com/support/modelHome?freeText=3000310 Try the website from toshiba to find where the light comes from. Are you sure it's not just the backlight?
5 Related Answers
Anonymous
  • 144 Answers
  • Posted on Feb 12, 2010
SOURCE: how do I reset a Toshiba Satellite Laptop to its
you use the backup disk or purchase a windows installation disk please rate if i helped
Anonymous
  • 11 Answers
  • Posted on Mar 18, 2010
SOURCE: Reset toshiba satellite A100-TA2 to factory settings
try this link, at appears as if u can download the disks here
http://www.user-guides.co.uk/toshiba/toshibarecovery/toshiba.asp?keywords=toshiba+satellite+a100+ta2+recovery+discs+downloads&recor=121
Anonymous
  • 178 Answers
  • Posted on May 02, 2010
SOURCE: Sony Bravia No signal plus flickering image and
You know how to reset the tv to its factory setting, I think you are a technician. Second thing you can do is software update. Go to http://esupport.sony.com/US/perl/swu-list.pl?mdl=KDL42V4100&LOC=3#div_pos_30 . If it doesn’t work. Replace the Main board (UB board). Part # A-1547-086-A Cost approx $320.
Knowledge obtain from: Repair experience on same symptom.
Parts reference: Andrews electronics, 800 289 0300.
Anonymous
  • 14553 Answers
  • Posted on Sep 14, 2010
SOURCE: red distorted color near top of screen not having
Reset will not cure a convergence problem.
this model (ws-65711) uses a single convergence chip located on the middle circuit board (see photo).
If convergence is skewed and will not adjust in customer menu the chip needs to be replaced.
Good news: I have start to finish, step by step instructions for this repair in this set. They tell you everything you will need and exactly how to do the repair.
No two sets with convergence problems will look exactly the same but I will also attach a few photos of this kind of trouble.
If the photos or what I have told you told you something you did not know and you want the instructions (free) rate this solution as very helpful as I do this here for free.
SD TECH
31e1a0a.jpg CONVERGENCE CHIP USED IN THIS MODEL.
3215424.jpgTYPICAL BOW FROM CONVERGENCE PROBLEM
ANOTHER SET WITH CONVERGENCE PROBLEMS
Testimonial: "This seems to be the problem I'm having Tks for the information great help look forward to getting your instructions to replace the chip. "
Anonymous
  • Posted on Jan 30, 2011
SOURCE: I have micromaxx x600 and
my x600 icons need to be reset how do i do this
What cause Vertical lines on my Toshiba TV Model 46G310U that affect the way the image is seen. Also some white bands Horizontally are appearing?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
How do I restore factory settings for my toshiba tv/dvd model: 32dv502b
Hi Michael! Here is a Web tutorial for resetting your Toshiba TV to it's factory settings. Give it a try. If it doesn't work for you, go to the support tab in the upper right corner and click on community forum. You will be able to get someone live to help walk you through it.
http://forums.toshiba.com/t5/Televisions-Knowledge-Base/How-To-Reset-TV-to-Factory-Settings/ta-p/266407
Toshiba 46g310u turns off and on by itself
The problem is a voltage dip. I can reproduce this on the same model TV by turning on the A/C or the oven and dryer at the same time. As soon as I hear the thermostat click on the TV shuts off. Just order a voltage regulator today, will see if that works.
I have a Toshiba 46g310u LCD TV it shuts off randomly and then after 1 minute comes back on need help
There is a repair for this on ebay, go to ebay and type in Toshiba 46G310U repair service, and it will come right up.
2helpful
2answers
Toshiba 46G310U randomly turns off then back on
Finally figured out the issue with this. It's a momentary dip in voltage caused by the A/C, dryer or fridge coming on.
I can reproduce this everytime by turning everything on, then starting the clothes dryer.
Why is my LCD TV not powering on after resetting to factory settings?
Kindly study the operation manual and follow instructions for installation from the beginning. You may have to switch off the TV manually, switch off power, remove plug, wait for sometime and retry this.
I have a toshiba flat screen 42 inch. i went to change the channel and now all i have is a white screen and no sound
Hello
The tuner card in your TV is not working I thinks. Anyway set the TV to its factory defaults. It will make all the setting to factory levels. If this also didn't helep you, repace the tuner card.
To restore the TV to its factory setting:
[1] Press Menu and open the SETUP menu.
[2] Highlight INSTALLATION and press ENTER. A new set of installation menu will appear.
[3] Open the SYSTEM STATUS menu. Hilight the SYSTEM INFORMATION, and press ENTER.
[4] Press [ => / [5] Enter your PIN code (or 0000 if no PIN code has been set).
OK
1helpful
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
