SOURCE: Milwaukee Sawsal Broken blade
Spay inside where blade fits in with PB BLASTER & let set a while. Maybe you will get lucky & the blade will fall out as it should. If not then it will have to be dissembled in this area. There are 2 BB's inside that fit into the small hole on the blade. They are forced in by a spring, be careful not to lose these. Also check the accuatator when you pull the finger release, make sure it is going all the way or it is not broken, Good luck.
SOURCE: Milwaukee jigsaw with blade change problem
a new tool will cost you about 170. You could look for a used on on craigslist.
SOURCE: I have a Milwaukee sawzall 6509-22 with a quick
K you used the saw after inserting blade?? If so couple ideas, hold collar open and put saw blade in a vise and try pulling back on saw, or you can remove the quik lok cam and release it that way, its not that hard, but I would try vise first. Let me know
SOURCE: I have a milwaukee jig saw, 6268-21 that I cannot load blades.
Yes the Milwaukee 6268-21 does require the use of certain jigsaw blades. You have to use T-shank type blades. You push the tension lever hold it while putting the blade in as far as it will go, then you release the tension lever slowly and it will engage the blade. You should then check by pulling on the blade to make sure it is seated properly and will not come out.
SOURCE: How to lock the jigsaw blade to make straight cuts on my Boschest 1587svs?
Use a straight edge guide. Clamp it on the work so the jigsaw can run against it. Be patient and go very slowly.
Testimonial: "Thank you for taking the time to trying solve my problem, however, I defiantly can't clamp a straight edge to everything I try to cut with the jig saw, many times it's simply not possible or practical such as in when I'm cutting a section out of a boat's floor."
