Freezers Logo
r
ray cheung Posted on Jan 09, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Danby upright freezer DUF808WE - quit working overnight after 5 years of operation and it has no indication of any type of operation. neither cold nor hearing any motor sound. Please advise.
Chris Huff
Level 3:
Top Expert:
  • Danby Master 6,289 Answers
  • Posted on Jan 10, 2019
Chris Huff
Danby Master
Level 3:
Top Expert:
Answers
6289
Questions
Helped
2020443
Points
74913
If compressor not running at all, it’s either a power supply problem, or a thermostat / control board
5 Related Answers
Anonymous
  • 136 Answers
  • Posted on Mar 13, 2008
SOURCE: Quit working -Haier Freezer
You have one of three issues here.
Either the thermostat has gone bad,
The thermal cutout has gone bad ontop of the compressor,
or the capacitor is out for the compressor.
Take an hom meter and check the thermal cutout, it should read 0 ohms or "continuity" if it doesnt the cutout is bad.
The only real way to check the cap is with a cap meter.
as for the thermostat check it with a n hom meter to make sure you have good connections internal the thermostat.
If you have any other questions just let me know!
Anonymous
  • 11 Answers
  • Posted on Nov 28, 2008
SOURCE: My GE upright freezer does not get cold.
Sounds like the system is low on freon. The other common problem is a dirty condenser. Insure the condenser is clean, if it is. You will need to charge the system with freon. Which only a qualified refrigeration tech should do.
Anonymous
  • 108 Answers
  • Posted on Mar 09, 2009
SOURCE: White Westinghouse upright freezer not cold enough.
Coils are probably underneath. remove the grille at the front (usually you just rotate it down to pull off) and then vaccum inside with a wand. If there aren't any coils there either, pull the machine out from the wall, and remove the lower panel from the back side. Inside you should find a fan next to a coil. Make sure that fan is working, and if it isn't make sure it is getting power.
Vacuum out as good as you can, and if you can use compressed air to blow it clean, even better (vacuum first because it will kick out a lot of dust).
If vacuuming the coils doesn't work, then you probably have a freon leakage problem, in which case it is probably not worth the cost of repair.
Anonymous
  • 998 Answers
  • Posted on Aug 17, 2009
SOURCE: Green indicator light not working on Beko freezer
should pry out
thumbs up
Anonymous
  • Posted on Feb 15, 2010
SOURCE: Maytag upright freezer (MQU1556AEW L1)top shelf
my maytag freezer not wotking correctly, the top shelf not cold, I bought a meat and tryed to put it on the top shelf, unfortunately, my meat went to the garbage and just the botttom shelf takes time to freeze, better than the top shelf
any help ?
1helpful
I have a Danby DUF808WE upright freezer. It works for a while (days/weeks)then stops. If I wack it on the top it starts up again and runs again. What do you think the problem is?
In that model the Temperature Control often is the culprit.
When the freezer gets very cold it shuts off.
The because it is not running it gets warmer and will start to work again.
I would perhaps focus on the Temperature Control.
Danby freezer
If it stopped working after being moved, check all the electrical connections. Also check no pipes were broken in the move. Is there any noise from the compressor?
Mar 23, 2014 • Freezers
2helpful
2answers
We have just moved a freezer and pluged it in but it doesnt turn on. it is pluged into an outlet with power i tested that
The Danby freezer(DUF808WE) doesn't work from yesterday, even proper plugged in?
I already check electrical outlet. How can I fix it?
I have a frost free upright ge freezer that quit working. No cold at all. It is less that 2 years old. Where did the quality go in GE? I have a GE microwave and it broke within the first year. Is it me or...
when the compressor is working and dont produce cold maybe the tube is leaking, causing the freon gas to scape. you need to reprocess your freezer to clean up and to find leaking tube to fix it. you nee a white line technician to fix your problem.
20.3 cu. ft. Upright Freezer GLFU2067F: We have an upright frigidaire 20 cu feet that is a...
Sounds like frost bulidup from door being left open warm air gets in making frost and ice. Need to turn off for 24hrs or so to let all the ice melt compleatey then turn back on keep door closed run for 24hrs check Temp. shoud be about 0 to -5 Deg. if good start using.
Can I put my Danby upright freezer in the garage? - it is not frost free.
It is always best to keep these types of equipment in the 60-80 degree ambient.
2answers
FREEZER NOT FREEZING CONTENTS
I have a similar problem with danby and have been unable to get help - I now HATE Danby Chest Freezers
Noise Problem
Is it a frost free freezer ? if it is it sounds like the evaporator fan motor making the noise
Top Danby Freezers Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Thomas Perkins
Thomas Perkins
Are you a Danby Freezer Expert? Answer questions, earn points and help others
