Model number PFSS2MIYC SS
How do I disable my GE refrigerator door alarm?
It looked like your model does NOT have an external ice/water control panel which has caused beeping problems on some models.
For your model I would try the following....
Door Alarm
The main cause of a beeping GE unit is an open refrigerator door. Some models are equipped with an internal door alarm, which trips when the door remains open for 3 minutes or longer.
One way to check this .... put your smartphone in the refrigerator on video mode and close the door. The light should go off with the door shut. If the video shows that the light stayed on when the door was closed ... then it reinforces that something is wrong with the switch/alarm. Repeat video for the freezer.
Door Seal
If beeping persists after the freezer or refrigerator door is closed, the door seals may be blocked or so dirty that the internal door alarm is tripped. The seals can be cleaned with a soft cloth and warm, soapy water. Also, an item inside the refrigerator may be preventing the door from fully closing.
Cooling System
Reactivating the refrigerator's cooling system includes a beeping noise. When the refrigerator is off, the "Off/Off" light appears on the door display. When the "Adjust Freezer" and "Energy Saver" buttons are held down for approximately 3 seconds at the same time the beep sounds and the "Off/Off" indicator disappears. Hold the "Ice Off" and "Freezer" buttons to activate the cooling system inside of the fresh food compartment. A beep signals the system is activated. The beeping should stop after the cooling system turns on. If it fails to stop, try unplugging the power cord to reset the connection.
Power
The GE's internal door alarm can get stuck. Try unplugging the refrigerator for about 10 seconds and then plug it back in. If the beeping continues, the internal door alarm might be broken or defective. Contact the manufacturer or a technician for further assistance. One way to check this .... put your smartphone in the refrigerator on video and close the door. The light should go off with the door shut. If the video shows that the light stayed on when the door was closed ... then it reinforces that something is wrong with the switch/alarm.
Good luck on your troubleshooting!
SOURCE: Replace an Interface Disp ASM on GE side by side
Part number WR55X10415 . Pull out from the bottom of the board , may have to use a small screwdriver to pry outward from the bottom to remove . Would suggest removeing top cap on freezer door and unplugging connector first .
SOURCE: GE Profile Fridge Model No. PSC25MSWA SS not making ice
Check to see if there is any obstruction (object of any kind) in the ice cube mold area. If nothing found, you will have to replace the icemaker, as individual repair parts are not available.
SOURCE: GE Model PSC23SGRC SS Serial #RH418861.
I suggest a defrost with doors open over night, what often happens with this model is that you get an ice build up near the fan which causes an extremly loud noise, very common problem.
SOURCE: Ge Artica Refrigerator PSC23PSTA ss not cooling or
Typical problems that can cause this:
- iced up evaporator due to defrost problem
- failed thermistor (temperature sensor)
- compressor not running
all of the above could be due to a failure in the main control board
there is a diagnostic mode that can help you diagnose cause
