Computers & Internet Logo
S
Sonya Parker Posted on Jan 07, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Medtronic pacemaker machine when I pick the handheld device up and put on my pacemaker I keep getting a error code (3230)
DocZachary
Level 3:
Master:
  • The Master 533 Answers
  • Posted on Jan 07, 2019
DocZachary
The Master
Level 3:
Master:
Answers
533
Questions
Helped
167813
Points
2496
Https://www.youtube.com/watch?v=iAQex-aXHEo
Watch video by clicking link above.
Goes through the procedure to get your reading without the error code 3230 issue.
Good luck.
Semper Fi,
Z
1 Related Answer
co7196
Ned C Cook
  • 3433 Answers
  • Posted on Sep 22, 2009
SOURCE: How to perform a pacemaker check, have a medtronic
I think that is a doctor thing. unless you want some dummy to tell you how to kill yourself.
Riso CV 3230 Digital Duplicator. ERROR CODE C02-253 in RISO CV 3230
Error Codes > Riso > SF5350 > Code C02 253
Printcopy.info https://printcopy.info > brand=Riso > code=C02 253
Code: C02 253 · Description: The master for the master roll has run out (or is running out). · Causes: No-master error has occurred five times on the same master ...
Missing: 3230 ‎' Show results with: 3230
Riso MZ790 error C02-253 Replace Master Roll ~
Copytechnet https://www.copytechnet.com > ... > Digital Duplicators
Dec 30, 2017 - Re: Riso MZ790 error C02-253 Replace Master Roll ~ Hold yellow reset while turning machine on, update firmware, check wire harnesses, etc...
Riso MZ series error codes T03-504 & T03-514 - Copytechnet
Jan 9, 2013
Error Code Riso CV3030 T01 - 537 error - Copytechnet
Aug 13, 2018
Recurring jam on Riso RZ 370 - Error code : J08 - 409
Jan 27, 2019
Error Code T20-437 on a RZ990 - Copytechnet
May 17, 2011
More results from www.copytechnet.com
2answers
How to fix Riso cv 3230with error code p 01 -537
To fix the error code P 01 -537 on a Riso CV 3230, you will need to reset the machine. To reset the machine, press and hold the Stop/Reset button for at least five seconds. This will reset the machine and clear the error. If this does not work, then you may need to perform a deep reset of the machine. To perform a deep reset, unplug the machine from the power source and then plug it back in. Allow the machine to go through its startup sequence and then test the machine again.
Can I use a samsang galaxt 4 tablet with a pacemaker?
Yes you can, your pacemaker has to have a strong magnetic field to interfere with it.
Here is a list of devices and whether or not they will interfere with your pacemaker from the American Heart Association.
Devices that may Interfere with Pacemakers
WHy do i keep losing my pictures on my cannon camera, I am fitted with a tri-venticulal pacemaker
try changing the memory storage device for a new/different one (often an SD card - I don't know for the A470) Just a suggestion. I doubt your pacemaker has anything to with it (do ther pepe when using your camera experience the same picture loss ?).
14.July.2014
My pacemaker starts throbbing in my abdomin at 17.15 hrs every day which lasts for 3 minutes. is this normal
Boy is this posted in the wrong place. "If the pacemaker has one lead, it is known as a single chamber pacemaker. The lead can be placed in either the right atrium or the right ventricle. This type of device can be used only if the signal from the SA node or the AV node is the problem, and all other electrical conduction in the patient's heart is working correctly. Patients with this type of pacemaker can sometimes feel an uncomfortable neck throbbing, chest fullness or faintness when the device fires, known as pacemaker syndrome. Because of this problem, and the general ability to pump a greater volume of blood, some patients are treated with a dual chamber system."--BNET
http://findarticles.com/p/articles/mi_gGENH/is_20050229/ai_2699003575/
How to perform a pacemaker check, have a medtronic device
Sep 22, 2009 • Plumbing
3helpful
7answers
Blackberry 7290 issue
my blackberry 7290 keeps saying device error:400 then below says reset i keep reseting it and nothing comes but it keeps saying reset .. wat can i do ?
1helpful
Sim registration filed on my nokia 3230
please try that sim in another mobile if it still get error message then that means ur simcard is faulty. but if that work fine in another then that means your 3230 is faulty and you have to format that. format with following code: *#7370# after that it will ask for another code then insert 12345, your mobile get formatted now. keep in mind that your all data on phone memory of that mobile get lost, if you that. if nothin get right for you then you have to go nokia service centre at last.
May 15, 2007 • Nokia 3230
Top The Computers & Internet Experts
Alexander
nexrad_chris
vince
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
