SOURCE: Clothes do not get dry when using the sensor dry setting on GE dryer.
Ok, Jeff, I see you have a front loader, electric. On this model we have inlet thermistors, outlet thermistors, and the sensor bars are non serviceable, which means they are part of the blower housing. Not a big deal. Let's put it into a test mode and test the voltage drop of the sensors. They are on the inside of the drum just below the vent gate. 2 bars. Unplug the dryer for 30 seconds. Plug it back in and within 10 seconds press in this order: signal button, delay start, signal button again and delay start again. The consol should show t01. This is test 1. You want to turn the main dial clockwise until the test shows t09, this will be the sensor test. With the drum dry it should show around 5 volts DC. Now take a wet rag and place it over the bars, the display should show a voltage drop to around .5 or 1volt DC. If it does this the sensor is working properly. See if you can run this test successfully and post back. Catriver.
SOURCE: elec. Whirlpool dryer shuts off before clothes are dry, unplug to
I doubt it is your motor that is causing the problem. It's always nice when someone says that it is the most expensive part to fix and that is the only solution. It's an electric dryer and there are tons of things that could be causing the issue for you. It sounds like the problem is probably the thermostat. What this does is shuts off the dryer if the heat is getting to high in the dryer. It is a safety feature to prevent it from catching on fire. It is a easy and cheap fix. The thermostat is located usually somewhere near the heating element housing and only costs around 20 dollars at any appliance repair shop. There is a wire diagram located behind the backing of your control panel. Just remove the few screws and take off the housing. It will help you locate the thermostat. If the motor was the problem your dryer wouldn't shut off the way it is. The thermostat is just shutting it down for safety and that is why you need to keep unplugging it to reset it. Change it out and it should work just fine for you. If you have any other questions let me know and good luck to you.
SOURCE: DRYER RACK DOES NOT DRY CLOTHES
try timed dry cycle instead of the auto-sensing setting. In your drum if you have auto dry such as less dry normal dry and more dry, There is a sensor sometimes in the drum and sometimes in the exhaust right after the blower. If in the drum then your clothes brush by this and if moisture is sensed then it keeps on drying. With your rack the clothes can't touch the sensor so it tells your dial to turn and that items are dry which in fact are not. Try this and see how it does.
SOURCE: DV448AEP sensor drying doesn't seem to work
I had the same problem with mine. My wrinkle free setting some how got turned off. As soon as I turned that back on machine kept running and dried the clothes fine.
SOURCE: my dryer takes long time to dry the clothes. It
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
NOTE***(This unit is equipped with a dryness control board. if all points above check out ok, replace this board).
