Home Logo
A
Anonymous Posted on Dec 29, 2018
I'm renting a house with a kohlar jakoozi tub and I can't figure out how to drain the water from it. I'm not sure what model it is but it has6 jets on each side and 10 on the back.
Thomas Perkins
Level 3:
  • Master 15,088 Answers
  • Posted on Dec 29, 2018
Thomas Perkins
Master
Level 3:
Answers
15088
Questions
0
Helped
3389770
Points
54869
Get a water hose,place in tub,connect to water outlet,turn on for a minute,then turn off.then disconnect hose,then water will come out.
5 Related Answers
Anonymous
  • Posted on Jul 05, 2008
SOURCE: No Water entering machine at all.
Hi, I was having the same problem but with a G572 (that's about 10 years old) though this might help you still as i believe they're all built fairly similarly.
My problem is I would start the cycle and I could hear the motor in the pump turning however no water would enter the machine.
Open the front door and look at the sprinkler on the base. Underneath it is a small tower (about 3cm high) and it has a cap on top of it. Take the cap off (mine just pulled off) and clear any grime that has built up inside of it. Now try to use the machine. (while I was clearing the grime I could actually hear something neutralise, as if there was air pressured up behind the grime).
I hope this works for you.
Anonymous
  • 1902 Answers
  • Posted on Feb 11, 2009
SOURCE: Jacuzzi jets not pumping out water
Check the jet pump, also where the filter is there are two 90s plastic. make sure that they are both in the water, if all those check out then check the switch for the jets. It sounds like the pump is bad and is not pumping the water. Even if the motor works and the internal parts of the motor seal gets wet then it all needs to be replaced and rebuilt. Very easy to do yourself. Like always be careful and unplug the unit.
Anonymous
  • 121 Answers
  • Posted on Feb 16, 2009
SOURCE: My ge quiet power 3 dishwasher will not drain
must be a pump
Anonymous
  • 62 Answers
  • Posted on Jul 11, 2009
SOURCE: Lasco whirlpool tub leaks. Water runs out on
Sorry, the tub will have to pulled out to find out what is leaking so it can be fixed. There is just no other way UNLESS you can open up the wall on the blind side of the tube. (but its probably and exterior wall...if the house is vinyl sided, it can be done. If brick, you'll have to pull the tub). If you just wanted to convert to a tub only, maybe Bathfitters has an insert solution...
Anonymous
  • 248 Answers
  • Posted on Oct 03, 2009
SOURCE: i have a leaking jet in a pearl jet tub. it's an
one of the quick ways to fix leaks at jets is by using Millaput two putty resins mixed and worked round the outside of the defective jet hope this helps
Aeromax tub some jets not blowing air
Hi Claude.
If your spa jets appear to be pulsating or pausing, first check to make sure your filter isnot clogged. If your filter appears to be okay, you should next take a look at your hot tub's water level. If there is too little water, air could be working its way into the system through the jets.
Why are My Hot Tub Jets Not Working? ' Master Spa Parts
How to Replace Water Jets in a Hot Tub
  1. Turn off your hot tub. ...
  2. Reach into the tub and grasp the outside edge of the damaged water jet. ...
  3. Place your water jet face down on a level surface. ...
  4. Line up the notched tab on the back of the jet with the groove inside the jet housing. ...
  5. Turn on your hot tub.
  6. Things You Will Need. ...
  7. References (3) ...
  8. About the Author.
How to Replace Water Jets in a Hot Tub ' Home Guides ' SF Gate
How To Clean Bathtub Jets with Basic Household Ingredients
  1. Fill the tub until the jets are covered by 2-3 inches of hot water.
  2. Add 2 Tablespoons of a low-sudsing dishwashing liquid and 1/2 cup of bleach. ...
  3. Run the tub's jets for 15 minutes.
  4. Empty the tub, and refill it (cold water is fine this time). ...
  5. Drain the tub and rinse it well to get the gunk off.
More items...
4 Sep 2014
How To Clean Bathtub Jets with Basic Household Ingredients ...
or read up more at this link.
https://www.google.com/search?q=Aeromax+tub+some+jets+not+blowing+air&rlz=1C1AVFC_enGB797GB798&oq=Aeromax+tub+some+jets+not+blowing+air&aqs=chrome..69i57.7532j0j9&sourceid=chrome&ie=UTF-8
Apr 28, 2019 • Home
How to clean jet on whirlpool tub
first of all you need to be draining the tub completely and removing any bath mats or items from inside. Fill the tub with hot water, ensuring that the jets are covered. You can use white vinegar, 2-3 cups of white vinegar directly to the water in the tub. Turn on the whirlpool system and run it for 15-20 minutes. While the jets are running, use a soft-bristled brush to scrub the jet openings and the interior walls of the tub. Drain the Tub: Refill the tub with clean water and run the jets again for another 10-15 minutes to rinse out any remaining cleaning solution. This should help. This is what I did with mine
Do Mirolin water jet tub jets come out for cleaning ?
No they do not here is a simple way to clean the jets and the piping.
Regular Jet Cleaning
To clean the entire whirlpool system and tub exterior, follow this process every month or more frequently if needed. Don't let dirt and grime build up or you'll have more scrubbing to do to get the tub clean.
  1. Fill the tub with hot water, approximately an inch above the highest jet.
  2. Make sure the water temperature reaches at least 140? F (60? C).
  3. Add 1/2 cup of laundry detergent or the amount used to clean 1 load of laundry as recommended by the detergent manufacturer.
  4. Run the jets for 15 minutes.
  5. Drain the tub and refill with clean lukewarm water.
  6. Run the jets for another 15 minutes.
  7. Drain the bathtub.
  8. Dry the tub completely by wiping it down with a clean towel.
Jan 13, 2017 • Jet Home
How can i clean/disinfect my tub/jets really really well? Im not sure what is safe to use in my tub.
Log in to this link.www.wikihow.com. It will give details . you can use dishwasher detergent works well for me. fill the tub with hot water ,several inches above the jets, run for ten minutes or so , drain refill with fresh water run for ten minutes to flush system . drain again finished.
Nov 12, 2014 • Home
3helpful
Housing for jet is broken on spurlin tub
You can probably get one at your local pool and spa supply. If you do not have an acess door or access panells to that side of the tub, then you may have to take the tub out of its frame. You will first have to TURN OFF ANY POWER SUPPLY to the pump and any other device such as an optional heater etc. Then turn the water supply valves off and disconnect them where they exit the valve.Disconnect the drain by unscrewing the inner drain strainer where the water runs out of the tub and the screws from the trip lever (that works the stopper) and pull it completely out. Remove any caulking around the tubs rim and lift the tub from its frame. Make repairs and replace in this same order.
Jun 11, 2012 • Home
1helpful
I have a walk-in jacuzzi-type bathroom tub. When the automatic blower comes on it sends out a mildew smell. How can I get rid of it?
First of all, after each use, refill the tub with warm water and run the jets for about 10 minutes to clear out any excess debris etc.
To eliminate the smell/mildew/mold. :
-Fill the tub to above the jet level with HOT (over 140deg.) water
-Add two tablespoons of low sudsing dishwasher detergent and five cups of distilled white vinegar
-Run the jets for 20 minutes
-Drain the tub and use a tooth brush or any small brush to gently clean inside and around all of the jets and nozzles, remove all foreign material you can from the areas inside (disassemble the outter rings to do so) and around the outlets. Be as thorough as possible.
-Rinse and refill the tub with CLEAN COLD water and run the jets for another 20 minutes.
-Drain the water and the smell and mildew should be eliminated.
To prevent future mildew build up/odors once a month fill the tub with HOT water (again) and four to five cups of vinegar (no detergent) and run the jets for 20 minutes. Drain and fill with clean cold water running jets another 20 minutes. If the tub is used very often you can increase the scheduled flushing of the system to every two to three weeks. The mildew/mold flourishes in the warm wet areas inside the jet tubing and nozzles. Diligent maitenance is the best way to make sure you're not bathing with any unwanted guests in your bathwater!
-Take care
8helpful
2answers
We have a dreammaker spa, how do we drain it? the model is Fantasy
The Fantasy has a drain located in the toekick of the spa. You have to first remove the drain cap, attach a hose if you wish, spin the outer black ring counter clockwise to start the water flow, then pull the outer ring out away from the tub to increase the drain to full flow.
I understand that a screw driver is often needed to pull the outer ring out to achieve full flow. Therefore, I suggest another method. Take a garden hose and place it in front of the jet while the spa jets are on. This will force water flow thru the hose and prime the hose. Once you see water running from the other end of the hose, drop the hose in front of the spa jet into the footwell and as long as the loose end is lower than the end in the footwell, a siphon will drain the spa as fast as the spa drain will. Remember to turn off electric to the spa once you have established a siphon. You may have to bucket the last bit of water in the footwell. Goodluck.
I have an Eljer jet bathtub with a smell to the water when we bat
What you smell is algae forming in the pipes. If you have small black particles in the tub when running the jets, it is algae. Fill the tub with hot water, add 2 teaspoons of cascade dish soap and 1/2 cup bleach. run the tub for 15 minutes and drain. fill tub with cold water, run for 15 minutes and drain, tub is now ready to use. repeat as necessary.
Aug 02, 2009 • Home
2answers
Feb 11, 2009 • Home
Water comes up into our tub when washer drains
The washer puts out a lot of water when spinning/ draining, sounds like the house drains are not of sufficient size or possibly blocked causing water to backup into your tub, check house drains for blockage or install seperate drain for washer into main drain that your tub goes into.
Top Kohler Home Experts
john h
ZJ Limited
ZJ Limited
Are you a Kohler Home Expert? Answer questions, earn points and help others
