Hi Dave, if you do not have good radio tuning, you would have to extend the antenna and try the result
Regarding the Phono, check that the pua is clean, that there is no residue stuck
I sent you the link to download the user manual
I hope you find my comment useful
Greetings Franco Dosil
Hola Dave, sino logra tener buena sintonia de la radio, tendrias que extender la antena y probar el resultado
Respecto al Phono, comprueba que se encuentre limpia la pua, que no haya residuos pegados
Te envio el link para que descargues el manual de usuario
Espero que te sea util mi comentario
Saludos Franco Dosil
https://www.manualslib.com/products/Teac-Gf-350-652266.html
SOURCE: Teac GF-350 CD Shelf System
Firstly double check that the recordable discs you have bear the label "Digital Audio" on them as per the attached picture. Secondly what happens when you go through the finialise procedure in the manual? Do you see the ?FIn--d? display when you select the finialise button? Do you see ?NO TOC? and ?REC? indicators blinking at the next step? Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE: DVD Audio Output Stops
Hey Kelby,
I've had a similar experience where a DVD movie would be playing and suddenly my Denon would just shut off, I later discovered that my rear speaker cables were not correctly installed in the back so the reciever recognized it as a short and would just shut down. Just make sure your rear speaker cables are correctly installed (right to right and left to left and with correct positive/negative placement) and see if it still does it. If it's still happening, then I wouldn't know what it is. Good luck.
SOURCE: All systems function correctly but
Have you looked at the manual?
The product you're inquiring about is not showing in your post. Name the make and model first, then we'll look for the manual. Then (maybe) find a solution. You might find it at the manufacturer's support site or these guys...
retrevo.com
audio.manualsonline.com
hifiengine.com
usermanualguide.com
Google search: "(product) manual"
SOURCE: Radio works (tuner, volume control, cd) but no sound
If your radio looks to be working and no sound, open trunk and mounted underneath the deck lid you will see your amp or sound booster. It should have two plugs that plug into it. Unplug the one with two orange wires and with the car switch turned on, check to see if the two orange wires have power on them. If they don't get ready to take out the rear interior and underneath the rear carpet almost at the front seat you will see a big plastic sleeve full of wires on the passenger side. Inside this sleeve there will be one orange wire branching into two orange wires, check to see if it is corroded. That would be where I start.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Teac-GF-450K7-manual/id/23167bh436/t/2/
"ER **" (variable) IS in the manual on page 29 and it recommends power off, wait a minute and power on, which isn
TEAC?
http://www.retrevo.com/support/Teac-GF-350-manual/id/3841bh048/t/2/
Page 20. What does it say about WHY it won
