Bought off ebay
SOURCE: mini cooper key fob settings
Try pushing the unlock button twice.
Mechanic @ Large Mobile Automotive Service Tucson,AZ
www.mechanic-at-large.com
SOURCE: TWO KEY FOB IS NOT WORKING ONLY ONE
Have all keys with you inside the car and repeat again with the second key within 30 seconds...... "Press and hold the 'unlock' button while at the same time pressing the center 'lock' button three times. On the third time, release the 'lock' button at the same time you release the 'unlock' button." If you have a key with three buttons, ensure doors are unlocked. Put key in ignition and turn key over to 2d position where dash lights, etc come on. Pull key out. Press and hold the "unlock" button while at the same time pressing the center "lock" button three times. On the third time, release the "lock" button at the same time you release the "unlock" button
SOURCE: My driver door on my Mini Cooper does not unlock
drivers door latch is bad there is a module that is part of it and its not responding
SOURCE: programing instructions for buick 2006 lacrossekeyless remote fob
Transmitter ProgrammingImportant:
All transmitters which are to be recognized by the remote control door
lock receiver (RCDLR) must be programmed in a single programming
sequence. If the system is placed in program mode it will erase all
previously programmed transmitters upon the receipt of the programming
signal from the first transmitter. Up to 4 transmitters can be
programmed. Do not operate or program the transmitters in the vicinity
of other vehicles that are in the keyless entry program mode. This
prevents the programming of the transmitters to the incorrect vehicle.
Good luck
SOURCE: transponder chip in key fob
This will all depend upon what country you are in, and if the vehicle even has the need for the chip to be programmed at all.
When you put a proper key in the ignition, is there a antitheft logo that cycles with the other indicators?
VW antitheft indicator in the USA often looks like a car with a key under it
In the USA, thought the keys have a MEGAMOS RFID chip, no system was active until 2000, and on some models, not until 2002
A system requires a VIRGIN chip. Once the chip is programmed to a car, the chip is locked to that car. Some new software can unlock and refresh some chips, but not 100%
I had a client come in TODAY with a 2003 Passat, and an EBAY flip key.... I wasted a half hour programming time..... but I carry the lower half of remote, which hold the blade and the chip, so was able to fix client up, when EBAY failed.
If this was helpful, please post a nice review for City Lock in Boulder
Colorado listings on Google Maps, Yahoo etc. This listing will link you
to my website as well. On my website are resources for finding a legitimate locksmith near you. Be sure you are hiring a REAL locksmith!
Thank You
Jeff
