Check the rubber seal inside/around the door. I bet you have a tear or piece of seal that isn't making a solid fit and it's allowing (warm) room air into you freezer. This moist room air will either turn to water droplets and builds up to enough droplets to form puddles in the bottom of the freezer, or it freezes into a blob of ice around the door seal and this allows warm room air into the freezer. Otherwise you need an Appliance Tech to check the Freon refrigerant level. Most times its the door seal causing this problem.
I know that your freezer shows a drain in its floor but there is also a drain behind the rear wall and at the bottom of a tray that collects the water during defrost and is surposed to drain that water that comes during defrost and then drains to a pan below the refrigerator and next to compressor. The solution will be to clean out this drain that is hidden from site behind the rear wall. I am pretty sure you are having a defrost drain blockage problem. Most defrost every eight hours and over a period of time the drain line that comes down from freezer into a cup like object top middle and back of the fresh food section. If blocked by gunk or ice you will see trails of liquid leaking down the rear wall of fresh food compartment until it reaches the crisper drawers.This is not always the same with every model as you may see frozen ice flowing down ther rear wall of freezers on side by sides. Here is an example Click here=>Whirlpool Leak Photo taken by TechnicianBrian He has been around a good bit and deserves credit for his contributions. Here is another way to make this look more si mple in clip below.TechnicianBrian.comAnd in this photo are several parts listed in photo group #1 were it is most likely running down the wall=>MagicChef CTB1921AR fresh food section.If you still have questions please ask and rate me if I was able to explain this well enough. Every refrigerator is made different so these are examples only. The key is to find if ice or just gunk has blocked you defrost drain. Unplug and then remove the rear panel in back of freezer. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. Much more on this page=> Leaking Refrigerators! This is a common tip so I will be placing this post and add as we go new ideas listed in Sea Breeze Tips Section. If you run into any problems along the way of repair please let me know, Thanks, Sea Breeze
dependant on appliance you may have a small drain hose at the base of the appliance that drains the defrosted water away at regular intervals. Sometimes this blocks and the water that should drain away just starts to freeze over.
ice on top of freezer door they came out with a fix but does not work two vent holes on bottom of door seal mthem off with silicone moisture getting in if that don't work you need to take liner off and spray foam the liner cavities
Hi, Remove the rear inside panel of the freezer and locate the drain hole under the evaporator coils. Use a hair dryer and melt the ice. Make sure and get the ice out of the drain hole as well. After the ice is removed, be sure and flush the drain hole with hot water. A baisting surenge works great for the flush. I hope this helps you. If I can assist you further, please let me know.
CHeck to make sure your freezer is 0 to 5 degrees. If it is warmer than that the water valve wont open to the ice maker. Have you replaced the water filter?
Defected DEFROST HEATER can cause frost build up on the panel at the back of the freezer,and freezer stop cooling and ice frozen on unit so air could not flow to refrigerator side.Water will coming out caused of unbalanced freezing,and causing the flooding of water in the floor. You must change this defroster heater assembly so it will works normal again..
probably the defrost drain blocked. remove back panel from inside freezer and melt ice off with hairdryer and follow up with hot water till water flows away freely.
you may find all the pipework iced up and if so you have a problem with defrost system.
an alternative way is to switch off for 24 hours and leave doors open
