Electrical Supplies Logo
T
Ted B Posted on Nov 24, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Generac natural gas generator has no control lights and won't even turn over in manual mode. Brand new battery has been installed. 7.5 amp fuse appears to be good.
There was an under voltage signal in the display, in auto mode , prior to switching it to manual. The display totally disappeared at that point and I replaced the battery. The display did not return
Lawrence Oravetz
Level 3:
  • Generac Master 10,558 Answers
  • Posted on Nov 24, 2018
Lawrence Oravetz
Generac Master
Level 3:
Answers
10558
Questions
Helped
2700505
Points
29284
Appearing good and IS good is two different things. Use an ohmmeter to test continuity on the fuse. also look at the traces on the display board for open conditions or scorched components.
Testimonial: "Changed the fuse. Same result. Will have an electrician look at the board as I don't understand the term traces or open conditions. Didn't see any scorching. Thanks for replying."
5 Related Answers
ZJLimited
ZJ Limited
  • 17989 Answers
  • Posted on Oct 30, 2009
SOURCE: Where is the Hazard/Turn Signal switch located in
2000 Dodge Intrepid 2.7L SFI DOHC 6cyl
The Flasher is located front seating area, driver side, under left hand side of instrument panel between junction block and brake pedal.
Testimonial: "Yes, this was ver helpful. Thank You! PS. If that photo is the Lady that answered my question, OMG!!!!!!!!!!!!!!"
roniecon
Ronny Bennett Sr.
  • 6988 Answers
  • Posted on Dec 20, 2009
SOURCE: 1986 Toyota Pickup Instrument lights and tail lights out
Even though the relay is activated,I assumed you checked the out put?Also,You checked the voltage at the light sockets?With a meter,or test light ,check the fuse for the cluster lps,adjust them to dim,and to bright,the meter should act accordingly on the fuse.If it does not,replace the dimmer control,or head light switch,witch ever controls them.This may allow continuity to the tail lights as well.If the fuse is dead for the cluster lights,replacing the dimmer control,or head light switch will solve the problem,or,from another fuse ,supply voltage to the cluster lp fuse,one that is only hot with the key on,cause if you do this the dash lights will come on,every time you run the vehicle,day,or night.
toneman2121
toneman2121
  • 775 Answers
  • Posted on Apr 17, 2010
SOURCE: 2004 F-250, 5.4l gas. Won't start or even crank.
are you referring to the starter relay on the firewall? the voltage should drop to 0 when measuring across the signal path because the connection is made, essentially making it a piece of wire and there is no difference in potential between the two points. is there 12v to the starter motor? is the starter solenoid (located on the starter) receiving 12v? check fuses and fusible links. disconnect hot leads from the starter. remove the starter, and supply 12v directly to the motor. does the pinon gear extend and spin? starter.
toneman2121
toneman2121
  • 775 Answers
  • Posted on May 12, 2010
SOURCE: I have a 1969 Ford f100 3 speed manual trans,
i had a '71 dodge with three-on-the-tree that experienced binding and the only way to fix it is to replace worn parts. as for the lights, find out which connetor supplies power. perhaps it is faulty or loose. also, there may be a separate fuse located on or near the instument cluster specifically for that application.
Anonymous
  • 9 Answers
  • Posted on Mar 18, 2012
SOURCE: the 'theft system' light does not turn off with the key in the run position on my 1999 chevy cavalier. car won't start, it won't even crank over. the battery and the starter are brand
try locking your car with the key and unlocking it with the key, leave it for 30 second or so between the locking and unlocking , the car thinks some one has tampered with it
Generac 16kw generator starts on its own in automatic mode
Check the wiring from the utility through to the autostart control.; make sure all connections are solid and the wire itself is in good condition. New wire is no guarantee, several times I've had wire with a break somewhere in the reel. A non-contact voltage detector may helpful; start at the controller end, go to the other end of the wire, and see where you lose the voltage detect. It will detect voltage up to the break if you can keep the detector close enough to the wire.
Engine will turn over/crank but will not run
All internal combustion engines have the same requirements. They must have the correct air fuel mixture and source of ignition in order to run. Although I am unfamiliar with the system you have, the fact thst it will start without the air filter but won't with the air filter indicates that you either have a dirty air filter (you said yours was clean) or you have too much fuel entering the combustion chamber. Beyond that I would only be guessing the reason (air fuel mixture regulator, worn jet, wrong size jet, something else bocking air flow etc.)
4helpful
4answers
I have a new Generac 20KW Propane generator with a rtse 200A3 automatic switch. I had an electrician install the switch and make the connections from to the generator. The generator is blowing the 7.5 amp...
Sounds like the electritian wired something wrong. Control wiring for that generator should be:
N1 and N2 = 240 vac utility input
Wire 0 = ground
Wire 194 (15B) = + battery
wire 23 = transfer signal
Generac 4456 does not start on power loss
I install and work on these everyday. If you hooked up the transfer switch you probable have a control wire wrong. check the utility power sense wire. That lets it no when to start in auto. it could be a relay or fuses. or a control board.
4helpful
Start runs shutsdown
Typically caused by the fuel line (LP or Natural Gas) having a lot of air in it. Was your generator just installed, or was there any work done to the gas line of the building / generator? Consult local gas contractor / propane dealer / gas company for assistance in purging the fuel line.
A low battery can also cause this as well as the generator is not able to come up to starting speed quick enough. Try placing a stand alone battery charger on the generator and charge the battery. Also check the air filter as well.
OverCrank condition occurs when generator tries to start itself, or be manually started, and the starter spends too much time turning.
This can also indicate failure of the control board. This will need the expertise of generac technician. Call 1-888-GENERAC (1-888-436-3722)
M-F 7am-6pm Central
Top Generac Electrical Supplies Experts
vince
Paul Bade
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
