I have bought the Global x183 drone and got everything set up .But the drone is not taking off though the propellers starts .when I pushed the Key to take off and goes away with a beep but does nothing to the drone. I have done callibration aswell as metioned in the guide and tried recharging batteries but no luck.Anyone to help. done calibration have
SOURCE: Ignition switch? 1985 Nissan Pickup
I have the same truck I rebuilt, it, took 2 years. Its on car domain.com. heres the link.http://www.cardomain.com/id/Marine4x4
The problem is with the wire going to the starter, the relay telling the starter to work. it will get loose or caroded, check that first, it sounds like your problem. Good Luck!!
Dan
SOURCE: DISCHARGE WARNING LIGHT ON
It might leave you stranded. Because without the alternator. which I think is your problem your battery will run down in a very short time. Even if you had a new battery.Check the belt first as Toyota Ed suggested. If it's good, and not broken. Replace the alternator and if you have to, the battery also. One could affect the other.
SOURCE: 2000 Jeep Grand Cherokee. Locked
did you try calling a dealer sometimes they are the only ones that can reprogrm these things
SOURCE: 2007 yukon xl battery dead recharged battery will
We had the same issue with our 2007 Yukon Denali XL. Died on us twice after sitting for short periods of time; once we watched a DVD with the engine off and battery died within 10 minutes. The dealership kept it overnight to troubleshoot why the battery died so quickly. They said the radio was "pulling" too much from the battery. (They supposably fixed it) But again a few days later the battery died again after sitting overnight. We brought it back to the dealership and they brought in a GMC "expert" to replace the entire DVD/CD/Navigation system. They also replaced our battery with a much larger battery, similar to the ones that GMC puts in there diesel trucks. They had our Denali for 5 days, but it appears to be fixed now.
Getting it fixed correctly wasn't without headaches, but it was all covered under warranty, including the battery. And they are updating the nav w/ the new edition disc as well for no charge.
SOURCE: 93 GMC Suburban Wont Turn Over
I may not be all the way in park or the safety neutral switch in not working. Did you try and start it in Neutral? Also move your shifter around while the key is engauged and see if it will start.
