All my new dvds keep saying disk failure.
SOURCE: dvd player will not read disk
have you tried getting a lense cleaner as they sometimes get alot of dust and will stop signal from disk to the laser if this dont solve the prolbem then you are looking at replacing the laser unit itself if the cleaning dont work and you think you are capable of taking the casing off make sure you switch it off first this should send the laser to the center of the laser tray if you take the case off and it is not in the center it might just be that it has got jammed now sometimes gently pushing it back to the middle will get it working again if it is already in the middle then it could be that the laser needs replacing but if not in middle push gently dont gerk it it should be quite stiff to push any way when you push back to middle try a disk with the casing off but please make sure you dont touch anything whislt it is plugged in if nothing works then it probably is the laser but before you do anything as soon as you get the case off switch it on and put a dvd in and make sure the disk is spinning if not laser unit is nakered and need replacing let me know how you get on hope this is some help to you
SOURCE: dvd recorder funai
I have fixed mine with the same problem , all it needed was the lens cleaned , i used a laser lens cleaning disc from maplin for 6.99 and voila good as new.
SOURCE: FUNAI SV2000 WV10D6 DVD recorder Recording errors on new DVD +RW discs
HI,
You can try cleaning the dvd lens with a commercialy available cd/dvd cleaner.
SOURCE: Can't copy my disney vhs tapes to dvd
I'm assuming your Disney tapes are store-bought, as opposed to recorded off the air. If that's true, the reason you can't record them to your dvd recorder is because of copy-protection. Sorry...can't advise you how to break that.
SOURCE: panasonic dvd recorder wont record or play
It is also possible that you are trying to record using an already used -R or an unformatted RAM disk.
