20 Most Recent GoVideo Go Video VR3840 DVD Recorder/VCR Questions & Answers
2answers
Trying to record to disc from VHS After recirding
I answered this question previously and the solution remains the same;
how long have you been using the player and has it ever accept blank DVD-R discs in the past.
The problem might be as a result of weak laser (lens) or the blank discs inserted might not be compatible with player.
When the laser(lens) of a player becomes weak, it will not be able to read blank discs. It only takes a very strong laser to read/accept blank discs. If it happens that the laser (lens) is the cause of the problem, then it means you will need to replace the laser (lens) to a brand new one to be able to read blank disc. Though the player might be playing DVD and CD, note that blank disc is stronger when it comes to reading from the laser (lens), it requires sharper laser. I hope you understand this.
So, insert a CD into the player and observe if it will play.If it plays, then its obvious that your laser is very weak.
Concerning the incompatibility issue, I hope you are aware that there are various kinds of empty DVD discs such as DVD +, DVD -, DVD RW. Try any of this empty DVD discs as one of them as to be compatible with this DVD recorder.
Amongst the two topics discussed above, one has to be the cause of the problem. So its up to you to figure out which is the cause of the problem.
I hope you understand the above....
I wish you good luck.
5/8/2020 6:17:13 AM • GoVideo Go Video... • Answered on May 08, 2020
2answers
Trying to copy VHS to Disc-Says"Unknown disc"
1/2/2020 8:27:31 AM • GoVideo Go Video... • Answered on Jan 02, 2020
Doesn't work since I upgraded my TV service to HD. What can I do to make it work?
In what input do you have your DVD or video. Can you give more info?.
5/14/2015 3:29:33 PM • GoVideo Go Video... • Answered on May 14, 2015
No sound output at AVout.
Have you checked the amplifier?
10/19/2010 4:24:34 PM • GoVideo Go Video... • Answered on Oct 19, 2010
I have duraband video/dvd player model number
You have a bad video heads please have tech replace
8/19/2010 3:32:51 PM • GoVideo Go Video... • Answered on Aug 19, 2010
This is going to be
This means your DVD or Video Cass is copyrited and has what is called microfilm coating . This keeps you from transfering video and audio from one device to the next.
8/5/2010 6:15:40 PM • GoVideo Go Video... • Answered on Aug 05, 2010
About 5 years ago I transfered some vhs tapes to
You should not need another '3840 to finalize the disks. Finalization just ends the index, makes writing back to the disk near impossible. You should be able to finalize / close the disk using a dvd authoring program (Nero, CD BurnerXP, etc).
The catch may be that the disks that you created are formatted as DVD video, closing a video disk may not be the same.
Another possibility is to use an authoring program (like the above) to copy your un-finalized disks to fresh media, and specify the disks to be finalized (or closed) when completed. I would try this first, the only thing to lose is time, and a disk. Oh, and about 4.7GB of hard disk space to create the image if you only have 1 DVD drive.
6/30/2010 12:33:30 AM • GoVideo Go Video... • Answered on Jun 30, 2010
I need manuals for GoVideo vr3840
http://tv.manualsonline.com/mdownloads/cac8022f-9294-8304-7d6a-3f79e55b9879.pdf
5/30/2010 7:02:47 AM • GoVideo Go Video... • Answered on May 30, 2010
My remote for my sv2000 dvd recorder model#wv10d6 won't work
If your absolutly sure the remote doesnt work there is a power button on the unit its self. As far as a universal remote goes, I my self would like to know that. After much research I have found no info on another remote working
1/7/2010 10:49:17 PM • GoVideo Go Video... • Answered on Jan 07, 2010
Can not record channel 160?
all machines go only to channel 125 maybe you have channel 160 on cable box or sky just set vcr to channel 3 or 4 and channel 160 will come thru vcr to your tv
12/16/2009 8:45:50 AM • GoVideo Go Video... • Answered on Dec 16, 2009
I have a Go Video
turn off the machine and disconnect the power for 4 or 5 min's, then try again, if it still won't let u then record another DVD and try to finalize that if the other DVD finalize option comes up then the 1st DVD is the problem, if both show this unable to finalize symptom then you have a problem with the machine, my bet is on the DVD being defective.
11/9/2009 10:34:04 PM • GoVideo Go Video... • Answered on Nov 09, 2009
Won't complete initializing.
i did everyting today to fix this. bought new dvds, name brands different, tried finding codes, called the number. trust me. try this. clean it. thats All i did. cleaned it with a dvd cd cleaning disc, the one with two little brushes on it, nothing special, ran it until i heard the beep, popped my dvd in, they all worked. everyone, im still recording. i ran it about four times. now, if you tried to burn a dvd, and got the error, throw that dvd away. because i tried about ten dvds. after i fixed it, THOSE dvds were no longer usable. dont know why. hope this works.
10/4/2009 6:54:16 AM • GoVideo Go Video... • Answered on Oct 04, 2009
Unknown disk, please check disk again.
did you finalize your dvd? also, the following describes the answer to alot of dvd error problems.
10/4/2009 6:53:50 AM • GoVideo Go Video... • Answered on Oct 04, 2009
DVD's won't finish Formating. Getting error
10/4/2009 6:52:04 AM • GoVideo Go Video... • Answered on Oct 04, 2009
Televison & Video Logo
Popular Tags
60 questions posted
Top GoVideo Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • GoVideo Televison & Video
Most Popular Question
no sound output avout
  • Televison & Video
