Appliance turns on, once wash has been selected the red door lock light flashes and beeps every couple of seconds. Obviously an issue with the door lock, upon further inspection when closing the door it doesn't actually click and can been pulled open by not using the handle. What shall I do?
SOURCE: It doesn't start up, only beeps and red light flashes
pls try to use another compatible memory stick.
then confirm the status of your micro processor
SOURCE: Frigidaire Tumble Action Washer - lights flash, beeps, does nothing else...
If you have had a lightning storm or power surge it may have fried the electronics panel. That is what happened to mine. Once it is fixed you should put a surge suppressor on it that is rated for major appliances.
SOURCE: Indesit W1A 111 front load W/M
hiya
no need to worry they do this.
hope this helps
please dont forget to rate the helpfulness. thanks kj
SOURCE: F & P washing machine GW709AU not competing rinse cycle and then beeps and flashes light.
My Whirlpool washing machine is not stopping after completion of wash cycle instead it is repeating the cycle again. It is not consistent, but out of 3 washes 1 wash is happening that way...we are manually stopping machine by gaurding carefully when timer shows nearer to completion.
SOURCE: washing machine door locked indesit WD12X
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
