A
Anonymous Posted on Oct 10, 2018
Toshiba 242 model. Toner not reco night so call not photocopy clear.please tell me toner install code
didi2005
Level 3:
  • Toshiba Master 727 Answers
  • Posted on Apr 13, 2019
didi2005
Toshiba Master
Level 3:
Answers
727
Questions
Helped
428591
Points
1454
Make sure genuine toner is used...
5 Related Answers
Anonymous
  • Posted on Nov 26, 2007
SOURCE: "Waste toner tank full"message won't clear
I had the same problem with my printer. On the back of the waste toner cartridge is a tab that sticks out. A photoelectric shine thru this tab to let you know when the cartridge is full. My photoelectric had gone out and was giving the same error message. I took my printer apart and cut the wires loose on each side of the photoelectric and shorted them together to complete the circuit. The only problem in doing this is you have to occasionally check the waste toner cartridge yourself to make sure it does not overfill.
Anonymous
  • 226 Answers
  • Posted on Jan 29, 2008
SOURCE: toner install error
http://support.dell.com/support/edocs/systems/3100cn/en/UG/section21.html#1091115
basic troubleshooting for your printer
Anonymous
  • 4 Answers
  • Posted on Jan 04, 2009
SOURCE: Empty used toner not clearing
you have to go into service mode and reset counter.in your manuel
quennie732
  • 422 Answers
  • Posted on Jul 10, 2009
SOURCE: ricoh aficio 2035 keeps telling me to add toner
a part in the the toner hopper assy had the mylars come off, blocking the toner from going into the developer assy. P/N A2327263 (cover toner supply) I have seen this lots. -Carl
the p/n is for USA model.
Anonymous
  • 5 Answers
  • Posted on Aug 18, 2009
SOURCE: Xerox Model 2515 Will not clear Toner Empty Stop Error
I had one today with a toner low light with new toner installed. Turns out they broke the green cartridge retainer clip.
The toner sensor pn# 130K45680 btw.
let us know if it was the sensor.
Sharp AR-M316 photocopier. f2-02 error on it. How can I clear f2-02 error on this Sharp photocopier please?
Sharp ARM316 - Error Code: F2-02
PrintCopy .info https://printcopy.info > model=ARM316 > code=F2-02
Code: F2-02; Description: Toner supply failure. The value judged from the actual toner supply hysteresis differs greatly from the toner sensor value.
Missing: photocopier. ‎' Must include: photocopier.
My photocopy machine name is Toshiba e studio 2303A. Now showing in the display empty :Toner.
Hello -
Your Toshiba photocopier needs fresh toner.
Check the user manual regarding what toner to purchase and how to add it to the machine.
Best wishes.
3answers
HOW CAN I CLEAR CODE ERROR F2 40 ON SHARP MX-M453N PHOTOCOPIER?
That is a miss reading of the toner density sensor. Which is located in the developer unit Replace the sensor or dv unit. Also check the connection of the unit to the copier and the harness from the sensor to the dv unit.
2answers
How can I solve Toshiba e studio 257 photocopier toner problem?
Try turning the main power switch off or disconnect the power, wait 20 seconds then turn back on again. This should reset the toner.
Toshiba e studio 212 photocopier machine change the toner but massage low toner
The toshiba machine e studio 212 is zerox actual image on in side tray but we are select out side try the image is shifted on output paper.
Dear sir, i have toshiba e studio 212 photocopier machine I change new toner but give the massage toner low
on out side tray the actual image is garbage left side 1 inch but in side tray select the image is actual printout
Sharp Al1655cs copier black smudge down center of page about as wide as a pencil
Hi
Sounds like a fusing error . If your able to wipe the toner off the page its a fuser unit problem (replace fuser unit).
Also clean the copier's paper rollers. Marks on copies will occasionally be the result of a dirty paper-rolling mechanism. Simply access these rollers (your photocopier will likely have a plaque or series of signs indicating the locations of these areas) and wipe them off.
Clean the copier bed's glass plate. One of the most common causes of blemishes in photocopies is a dirty glass plate. In some cases a permanent mark, such as a scratch, will be present on the plate, showing up in every copy as a dark line or spot. However, most problems attributed to the glass plate can be fixed by wiping the plate with a soft towel and common household glass cleaner.
Clear any excess toner that has spilled or overflowed in the toner cartridge chamber. Excess toner will almost always result in blemishes on your copies. The most effective means of cleanup is to remove the toner cartridge and set it aside, thoroughly cleaning up any spilled toner in the compartment before putting the cartridge back in place.
Check for low toner levels. Low toner levels can actually contribute to unsightly lines and blotches on a photocopy. Most photocopiers will automatically indicate the need to replace an empty or low toner cartridge; while the toner is low, these models will permit continued copying. Consult your photocopier's instruction manual or key to warning lights and indicators for how to tell if the toner is low or empty.
2answers
Top Toshiba Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
