Unsure if this is the same watch reviewed on Amazon.com
https://www.amazon.com/SMAEL-Digital-Military-Waterproof-Multifunctional/dp/B07B7F5GH6?th=1
Apparently you have to pull the crown out to set the time, and then continue to set the week and day.
Question:
How do you set the watch for the week and day?
Answer:
When you choose to adjust the digital time. Please continue to press the button to select the adjustment position, the watch will appear adjust the date and day of the week.
By SMAEL Seller on January 2, 2018
Get a manual and find out. Free User Manuals and Owners Guides ManualsOnline com
SOURCE: changing settings
I just purched a new Kennith Cole watch I am unable to set the three didget date at the top ...any help
SOURCE: I can not change the date on my Wenger Swiss
As you pull the mainstem out, there will be a position, a 'notch' if you will, whereby as the hour and minute hands are rotated the date will change. Rotate ONLY clockwise, and when the desired date appears, be sure to turn an additional 360 degree turn on the hands if you are setting the date in the afternoon. Otherwise, the date will lag by 12 hours.
SOURCE: How do I adjust date of my watch bought from GAP
I think I figured it out: (Start + Reset) = toggle alarm on/off ("ALM" will display in upper left corner when alarm is on. (press Mode once) will bring you in chrono mode, where "start" button starts and stops the chrono, and "reset" button resets it back to zero (press Mode once more) will bring you to setting of time for alarm. Set the "hour" value by pressing "start" repeatedly, then press "reset" and set the "minute" value by pressing "start" repeatedly (press Mode once more) will bring you to setting of time for actual time. Reset the "Seconds" value to zero by pressing "start" button once, then press "reset" and set the "minute" value by pressing "start" repeatedly, then press "reset" and set the "hour" value by pressing "start" repeatedly (if it shows "H" in upper right corner, time will be displayed euro-style 0:00-23:59, if it shows "A" time will be displayed 12am/12pm), then press "reset" and set the "day of month" value by pressing "start" repeatedly, then press "reset" and set the "month" value (1-12) by pressing "start" repeatedly, then press "reset" and set the "day of week" value (Su-Sa) by pressing "start" repeatedly (press Mode once more) voila!
SOURCE: MENS WENGER SWISS MILITARY CHRONO NEW DATE WATCH 79200
Link
Maybe you can try above link to contact Swiss Wenger for the repair of your watch. It's best to send your valuable watch to its Authorized Dealer for repair.
Thank you.
I earned $5000 ultimate month by using operating online only for 5 to 8 hours on my computer and this was so smooth that i personally couldn't accept as true with before working on this website. if you too need to earn this sort of huge cash then come and be part of us. do this internet-website online ...........
>>>> www.payshd.com
