SOURCE: ironman 520e elliptical
i believe this is error occurs when the console doesn't get a reading from the gear box. while debugging a problem with the reed switch (the thing that detects motion, that you have started pedaling) I had the gearbox unplugged and it indicated error 1. once plugged back in, it was fine. possibly you have pinched/cut wires? I had this problem where the stem meets the body.
The gear box wires are red/yellow/orange for the servo positioning, and brown/black for power to move the motor.
SOURCE: My ironman 420e screen is turned on but blank and
Dear Sir:
You must do the following:
1) Tight the flexible cord or ribbon cable from keypad 2) Tight the connector from display board to main motor board(Lower board). 3) you must try to measure if +5vdc IS PRESENT is display board, other wise the main motor or display board is faulty. Run your software calibration for easy diagnose and troubleshooting.
see my block diagram for treadmil for better understanding diagnose.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
SOURCE: I need to know what ac adapter the ironman 530e elipitcal takes
http://www.treadmilldoctor.com/Ironman-530e-Elliptical-User-Manual?utm_source=fixya&utm_medium=CPC&utm_campaign=Mendi
or call Treadmill Doctor at 800-750-4766 and they will have it or let you know a good source to get it.
