Can i use this amp for mids only ? or can i use it as a bass amp ?
It can be used as a bass amp. if each pair of channels is bridged then you will basically have a 2 channel amp. just be sure to set the x-over's to lpf for subwoofers. I checked the power ratings, and bridged at a 4 ohm load will give you 250 rms watts per sub, so thats enough to run most 10's or 12's. there wasnt a rating for a 2 ohm load, but your amp should support it.
