SOURCE: Sharp Microwave model R-1850A door won't open
Hi ,there are two posibility to repair . 1. by ordering parts to the web site of sharp .
2. You may check from shop same type of part bring sample or in the appliances center near you.
SOURCE: door latch on Emerson microwave oven
u will need new door asemble to relly fix it ok thx nick
SOURCE: Sharp Carousel Microwave door latch stopped working door won't stay closed
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have *critical* safety & disassembly info at our site, linked here: http://tinyurl.com/yzjozk
We also have this full service manual at our site: http://www.microwavedisplay.com/R1480_R1481_R1482_sm.pdf
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: door latch on sharp 1480 microwave over the range oven
door panel.
We have the service manual for this model and have uploaded it to our site here to help you. You will need the free Adobe Reader to view or print it.
Normally
you have to separate the door panels (as shown in the manual)
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
The best place to order Sharp parts is Tritronics.
SOURCE: Door won't latch/microwave won't turn on
The door does come apart. Open the door and where the hinges are, there are openings where the hinges enter the door, this plastic piece (goes all the way around the door) With a small flat blade screws driver VERY carefully pry it (plastic) off, once off, check the latch end for the spring, typical failure for a Sharp is the little tab that the spring hooks to on the door, the only way to repair this so it will last is to replace the door frame. they are not too expensive, about $50 or so Part# FCOVB166KIT
is the door frame assy
