20 Most Recent
KitchenAid KEMC377K Convection / Microwave Oven Questions & Answers
Loose microwave door
My over the range microwave had a loose door, it sagged when it was open but you could lift it to close. Called repair person he said no it could not be fixed. You could see the bottom hinge was loose and slipping. I loosened 3 screws that holds the bottom on the microwave -you have to do this to change the light bulb also. The bottom hinge on the door was loose there was a hole there, so took a screw and nut to hold the hinge in place..I am a 70+year old woman-if I can you can.
Motherboard problem in a KEMI300wbl3.After a
There are electrolytic filter capacitors on the control board which, due to age, can weaken, causing some bizarre results.We've repaired several of these boards successfully, upgrading the capacitors and relays at the same time. It runs $39.95 and comes with a one-year guarantee.They're the same as the Whirlpool RM286- and RM288-type models.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.You can also find helpful exploded views
here.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
All the controls work and seems to be working with
Having noise means some obstruction near the rotating tray or its motor need some lubricant. Has for no cook but control seems working, the magnetron and its fuses is the culprit because it doesn't anymore produce heat to cook food.
I hope that advice help you.
Oven quit heating after cleaning
kitchenaid expert here
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE
REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Microwave is running sounds like it is heating but
This is a very complex repair, and should only be done by a technician that has worked on these a lot. The heating problem can be wiring, magnetron, safety thermostats, high voltage diode, transformer, capacitor, or control board. Out of all the brands and models we work on this is one of the toughest to work on because of the amount of labor you have to put into it, to get into the unit to diagnose this type of problem. I would recommend that you use one of whirlpools warrantee companies, as they will probably have the most experience with this model. Good Luck, Appliance Specialists.
Is there an electonic reset for 'door open'
If the switches are good (
test & order info here), and it's a Kitchenaid / Whirlpool of recent design (by L.G.) then they have more than one fuse inside.
There will be a fuse associated with the door circuit which will cause this problem, but not render the oven "dead".
There
should be a "mini-manual" (tech sheet) hidden inside the unit
behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting, testing, and locating
components.
At
If you don't find your mini-manual,
or if you want to look at it before removing the controller, you can
download it here (just enter your model
number).You can find links to helpful exploded view diagrams and part ordering help
here.
I recommend that you bookmark that link to your favorites.
We're
I have pluged in the temperature probe into the
You can download owner's manuals
and installation instructions for several brands (including Amana, Jenn-Air,
Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool)
here.
We're happy to help you with free advice and we'd appreciate your thoughtful
I have a KitchenAid Microwave that the tension
That model number does not look right. Please check the tag on or in the unit again.
You can find helpful exploded view
diagrams and order parts here.There
behind the
components.
At
If you don't find yours,
or if you want to look at it without disassembling the oven, you should be able to download it here.The door springs
must be replaced in pairs to keep the wear even.
We're
Microwave humming
hi! humming are cause of many things, either you have a defective magnetron, leaky capacitor, or the hv transformer. but most likely the magnetron is the culprit.
