SOURCE: Kenmore Side by Side Refrigerator - ice/water dispenser
The water will not dispense, its worked since we moved in but last night it just stopped working.
SOURCE: Rust on Jenn Air Refrigerator Door at Water Dispenser
You may end up respraying the door, but here goes.-
First mechanically remove as much of the rust as you can with an old screwdriver or similar scraper. Then use coarse emery cloth - 80 -120 grit untill all you're left with is shiny metal with rust pits.
You may need to go out further than you think - about 1" all round.
Then use a paint- on de-rusting fluid from vehicle products supplier. When all rust is black or dissapeared, use a zinc primer on all the bare metal. (this will stop it reacuring)
Then either spray the area with an "appliance white" aerosol or squirt it into the cap, and use a paintbrush.
If you are spraying it, open all house windows and doors, cut a mask from newspaper- then tape it to the fridge. Use blankets , plastic dustsheet or old sheets to protect things, and spray it from 12" in several very light coats.
When done, "polish" with T cut - which should remove the rust stain too.
Seal the area of the original leak with a white or clear silicone - and sort the original leak out.
If you polish the plastic with a silicone spray, water will tend to stay put rather than seep.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
SOURCE: Smell & bad taste of water from refrigerator dispenser
depending on the brand and the style, locate the filter and change it out. Please note that you must empty out the remaining water from the refrigerator cause if you don't, when you change out the filter you might get the same taste for a while until all the remaining water is replaced by freash water.
SOURCE: water does not fill ice tray GE refridgerator
Hi Alice. If I was nearby I would stop by and take a look for you but since we are cyber only I will assist you and yes, you can fix this yourself!
If your ice maker has stopped producing ice completely, check these, in this order:
In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
