SOURCE: pump runs continuously with not water
replace the pressure guage.
prime the pump by pouring in water in the impeller basket area and replace lid-try running pump again
SOURCE: i have a sta-rite pump it will prime but will not putout water
COULD IT HAVE A SUCTION LEAK PULLING IN AIR? RUNNING BACKWARDS? BYPASSING INTERNALLY ALL THE TIME? COULD YOUR DISCHARGE HOSE HAVE A RESTRICTION IN IT SLOWING IT DOWN? HOPE THIS HELPS, JODY
SOURCE: My Stay Rite Pump 1 hp, 230 volt model DS3HE - 01
pumps lose prime for a few reasons...bad foot/check valve, crack in the suction line are probably the two most common.. see if there is a threaded fitting( most pros put one on the pipe some where) on the top feed of the pump. open it up and add water til the pump fills up. if the pump is outside turn the pump on before resealing the fitting, otherwise resael the fitting and open a spicket outside. depending on your water table it could take some time to prime but in normal circumstances up to 20 minsif it does not prime you may want to consider hiring a pro!!
SOURCE: need manual on cleaing sta rite systems filter
http://www.pentairpool.com/pdfs/System3SMOM.pdf
SOURCE: reset button for sta-rite well pump kicks off
That could be a bad wire in the well or the pump motor has a flat spot...or a spot that if the motor stops there it will not start....also could be that the pump bearings are worn and the motor locks up once in a while...
Bottom line the pump will need to be pulled and probably replaced....
http://www.fixya.com/support/r3755320-electric_problems_submersible_pumps
heatman101
