There are several causes for piston not returning fully to top of cylinder. Here are some things to check. * Debris in the exhaust vent in the head preventing discharge air from flowing freely. * A slightly bent driver will have difficulty returning. It should be relatively easy to push the piston up or down with finger. If the driver piston fits too loose in the cylinder, there will be lack of power and piston will slide down easily or just be in the down position if there are no nails in the gun. * Missing or worn seal below the bumper. Most nailers have a seal or washer below the bumper. If worn, the air pressure will leak out the nose instead of pushing driver back up. If you suspect the bottom seal, you can make one out of innertube rubber. Just cut a circle of rubber and make thin slice or hole to allow the driver shaft the slip thru. *Finally, there should be a rubber check band or oring on the outer portion of the cylinder. The check band covers a series of holes. These holes are located within a groove or channel to hold the band. These holes are located below the bulkhead but above the vent slots near the bumper. If the check band is missing or broken, you can replace it with any oring or series of orings to cover the whole slot. Good luck with your repair.
SOURCE: paslode framing nailer when fired pin stays out wont retract
Check the anvil guide for damage first (ie: burrs, nicks, etc.) Then go to the chamber for the return spring. That is where your problems are.
SOURCE: Paslode (30 degrees) framing gun firing pin not retracting
The tool needs to be completely torn down, cleaned out, two orings inside need replaced, re-lubed and re-assembled. takes a technician about 1 hour to do it right. I believe either the orings or dirt is your problem. If blade doesn't return its probably the orings.
SOURCE: paslode framing nailer will onley fire one time
Did you remember to lube the upper cylinder, lg 0-ring and silicone the striking pin----sticking may prevent returning to firing position
SOURCE: my paslode angled finishing gun keeps jamming
Hi, heatman101
Here is a tip that I wrote
about the Paslode nailers and the problems that can come up
with them.
I also have a link to the Paslode manuals
which contain Paslode cleaning and troubleshooting guides.
If
you need parts for your Paslode, there also is a link for a
site that sells the Paslode nailer parts.
Paslode
Cordless Nailer Problems
SOURCE: paslode stapler not firing with new gas & new
Hi, heatman101
with them.
If
Paslode
with them.
If
Paslode
heatman101
Check the o-rings on the firing pin...
with them.
If
Paslode
heatman101
with them.
If
Paslode
heatman101
Bad 0-ring or bent firing pin...
with them.
If
Paslode
heatman101
with them.
If
Paslode
heatman101
