20 Most Recent
Craftsman Nailer Kit, Palm Air Driver Questions & Answers
Hi, I have a paslode
i had the same problem with mine,
the spark unit is held in posistion with either tape or silicon depending on the year, this can come loose in time, when it comes loose it puts stress on the wires that come from the circuit board above.
you can secure the spark unit again that can do it, if not you need to replace the circuit board cost between £25 & £30
No brad
Your anvil is not returning to the home position to allow the brad to index into the receiver. Try and push the anvil up all the way to the home position. If that works, then you need lubrication, new return spring, etc. All related to the anvil firing.
I have a craftsman framing nail gun model number
Hi, W/D here.
On the side of the slide that holds the nails will be a tab. If the gun is empty, it will be close to the base of the slide, near the head of the gum. Grasp the tab, and pull it all the way back until it locks in place. Load your nails. Now, near where the tab that you pulled back is locked in place, you will see a (usually) silver button. Pull back slightly on the first tab, then push the button, releasing the lock. Let the slide push the nails into place, and you're ready to go. Place 2 drops of oil daily in the nail gun where the air line connects, then hook up the air line. Fire away!
Here is a link to an exploded diagram of your nail gun. Double click the diagram to enlarge it. On the right side of the page is the link to a free download manual. Enjoy!
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Nailer-Parts/Model-351183200/0247/0732000?searchedModel=351-18320&blt=
Best regards, --W/D--
Please feel free to rate this carefully hand-crafted solution, made especially for you. Thanks.
Paslode 16G finish nailer fires intermittently.
Clean it and oil it according to directions, then put a dab of dielectric grease on top of the spark plug. If this does not work ...Change the spark plug. I found one spark plug that had broken in half and made good contact intermittently which caused the problem you describe
Paslode im90i fires ok but
my paslode im90i nail gun uses loads more gas than the calculated nails per gas and is costing me money
Paslode im 350 just cleaned
Here is a tip that I wrote
about the Paslode nailers and the problems that can come up
with them.
I also have a link to the Paslode manuals
which contain Paslode cleaning and troubleshooting guides.
If
you need parts for your Paslode, there also is a link for a
site that sells the Paslode nailer parts.
Paslode
Cordless Nailer Problems
heatman101
I have Paslode IM 250
with them.
If
Paslode
heatman101
