SOURCE: lost key
small sentry fp box #1110 can't find key and I need to open it. help me please--------need it asap
[email protected]
SOURCE: bunker hill safe
i had the same problem this is what i did. i took the lil leg off the bottem it held on by a srew take a cloths hanger put it in the hole and now u can hit the lil button that is for makin a new code it is on the hing side of the door the yellow light will come on and stay on now put ur new code in then hit a or b i used 1111a then changed it once i got in o by the way ''the factory code is 159a try this first" and the cloths hanger i shoved a ear plug on the end of it so that way it could grip the button hope this helps somebody
SOURCE: lost key
To order replacement keys, for small chests and files, you will need to know the key numbers which can be found right around where the key goes in. It should be a stamped number, letters, or both located around the keyhole. For Personal, Home and Home/Office Safes, you will need the model number and serial number. I think that the most economical place to buy keys is from www.SentrySafeShop.com. You can do a search for "lost keys" and it will give you a screen where you can enter your model number and key number. (It is a very easy screen to use. They just need 1.)Model # and 2.)Serial or Key #.)
In Summary:
For Small Chests or Files: A lock reference number is required. It will be a letter, a number, a letter and number, or "blank" (no letter or number), engraved/located on the silver cylinder of the lock. These are model numbers 0500, 1100, 1170, etc...
For Personal, Home and Home/Office Safes: (model numbers will begin with: S0, S3, S4, S5; I0, I3, I4, I5; A3, A4, A5; J3, J4, J5; L0, L3, ,CS,CSW,DA,DS,KS,KSW,MS,MSW,OA,OS,and SC): Indicate your model number and the safe serial number found on the front right-hand side of the door, between the hinges.
Here is the direct link to the key replacement screen: http://www.sentrysafeshop.com/Keys-Sentry-Safe-Replacement-Keys-p/keys.htm
SOURCE: gordon item#45891 digital safe, lost code the door is open
there is red button on the inside of the door (hinge side) press this , then key in a new code
SOURCE: Detroit electronic digital safe lost code and keys
Help, just boughta Detroit digital safe, code number to open my instructions are locked inside.
