SOURCE: Ductless heat pump systems
Fixr is correct. I do not recommend using the Mitsubishi or Sanyo below 17 degrees. It may cost you a fortune in electricity below 50 degrees depending upon where you live. Mitsubishi is the better model.
SOURCE: cold air will not turn on
This problem of yours should be handle by a professional on heater/cooler trying to repair it by yourself will just cause more damage because you should have a knowledge about this device so better ask a repir guy or take it to a repair center near you to avoid any problem with it...
Good luck.......
SOURCE: heat pump auxiliary heat does not turn on
Turn up your outside thermostat in the outside unit.
You should have about 3 degrees difference in one stage to the next. So I would change the thermosat with one that has three stages of heat.
SOURCE: freezing temperatures effect on LCD television
Just spoke with a vizio tech and they said the temp to operate is 41 degrees F. As long as temps don't go below -4 degrees F your tv should be ok. But if you are going to turn it on the temp needs to be no lower than 41 degrees F. I would let the room and tv warm up to at least 65 to 70 before I would turn it on.
SOURCE: ford ka heater blows hot air all the time
Your problem is a faulty heater control valve. The design used on these vehicles allows for hot water to flow constantly and compete with the evaporator as there is no blender door. You have to replace the valve and possibly the control head. Meanwhile, you can bypass the valve to have cold air
Hi THOMAS E WHITLATCH, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
