20 Most Recent
Sanyo 18KS52 Air Conditioner Questions & Answers
Sanyo KMS0712: Evaporator coils severely clogged
here is the service manual for your model unit...
click the link below to download the manual
service manual
here is the Schematic Diagram for your model which will be useful on cleaning and removing parts.
Schematic Diagram
Inside the House
Step 1
Remove the front grille. Most grilles are made to clip on the air conditioner, but some types might require a screwdriver.
Step 2
Remove the filter to expose the condenser coils.
Step 3
Use a vacuum cleaner to **** up any dirt and dust on the coils.
Step 4
Use a fin comb to straighten any bent coil fins. You can find fin combs at appliance parts outlet stores or from an air conditioning wholesaler.
Step 5
Replace the filter and front grille.
Outside the House
Step 1
Remove the back grille. You should be able to see the evaporator coils.
Step 2
Use a vacuum cleaner to **** up any dirt and debris on the coils.
Step 3
Step 4
Replace the back grille.
Step 5
Trim any foliage back by at least 2 feet to reduce the amount of dirt getting on evaporator coils.
please refer to this additional link for reference
reference link
Regards
Drain on Sanyo air conditioner
find the drain hole on the bottom/side of unit, with a thin piece of wire insert into hole, pipe cleaner may be used,also. Hope this helps Tim
