Computers & Internet Logo
J
Jerry Posted on Jul 28, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
A program may not function properly
I've got a strange problem with Outlook account on Sony VAIO laptop. I keep getting startup error message A program may not function properly. Really hope someone has a solution for this. i'm running out of ideas.
iV7KlXmxhk
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Jul 30, 2018
iV7KlXmxhk
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
855
Points
17
The PST repair engine, powered by PST Repair Set, easily fixes data corruption threats under any version of Microsoft Windows and Outlook. This application offers intelligent algorithms of file restoration regardless the reason of damage and the PST file version as well.
https://www.pstrepairkit.com/
Vebble
Level 3:
Master:
  • Sony Master 395 Answers
  • Posted on Jul 28, 2018
Vebble
Sony Master
Level 3:
Master:
Answers
395
Questions
0
Helped
108982
Points
1210
Do you have any photos of the error?
5 Related Answers
Anonymous
  • 37 Answers
  • Posted on Aug 21, 2009
SOURCE: SONY VAIO
Save Data if possible.
Use Restore System; Restore Computer to Factory "New" Condition.. Sont Vaios have a Key Prompt which you hold down while booting and the Replacement Software already on a Sector of the Hard Drive. Check THe Manuel for this OR CALL SONY CUSTOMER SERVICE AND JUST GIVE THEM THE MODEL NUMBER AND ASK THEM WHICH BUTTON YOU PUSH ETC TO RESTORE THE COMPUTER TO "FACTORY CONDITION"
Anonymous
  • 3 Answers
  • Posted on Sep 25, 2009
SOURCE: vaio care, vaio sat survey and vaio luncher have been stopped wor
I had the same problem , i was using a spanish date format.
I changed the date format to an english format (mm/dd/yyyy) and now all vaio programs work ok at start up and afterwards.
kornho
Francisco Cortes
  • 781 Answers
  • Posted on Dec 19, 2010
SOURCE: I can't get Outlook set up for my new ymail
my understanding is that you need to have yave yahoo plus to get this to work, yahoo plus is the paid version for you to have pop access which means be able to use an email client (like outlook) to retrieve yahoo mail there.
now if you have not paid for yahoo plus you can do the following:
1. switch your yahoo account to be localized to asia, which should also (for now) allow you to use pop access on a free yahoo account, you need to look around into the account options (Its under Account Info, Account Settings,Set Language Site and Time Zone or something like that)
2. once 1 has been completed go into yahoo and add your yahoo account, * for logon info use only your yahoo user name (not the @yahoo.com) * enter your correct password *for incoming email server: pop.mail.yahoo.com *for outgoing email server: smtp.mail.yahoo.com
3. go into more settings>advance * incoming server port should be 110 *outgoing server port should be 587
good luck
Anonymous
  • 16 Answers
  • Posted on Mar 21, 2011
SOURCE: Runtime Error! Program: C:/Program Files/Sony/VAIO Gate/VAIO
Hi,If you want to fix the problem you can try to reinstall the application. If you just want to disable the message you can try this:
1. Go to Start Up \ Run command and type: msconfig then press Enter. 2. Go to Windows StartUp and search the item with this string: "C:/Program Files/Sony/VAIO Gate/VAIO Gate.exe" and remove the check. Then Apply and Close.
Anonymous
  • 674 Answers
  • Posted on Jul 19, 2011
SOURCE: sony vaio vgn-fs775p laptop real time clock not keeping time
Properly Configure Time Zone
Make sure that you have properly configured the time and selected the right time zone. Configuring the time zone properly may fix clock that keeps resetting. To do so follow these steps:
  1. Click on Start
  2. Open Control Panel
  3. Click on Date and Time
  4. Click on Time Zone
  5. Select the right time zone by clicking the arrow below
  6. After selecting time zone don't forget to click "automatically adjust...."
  7. Click OK
Check CMOS Battery
There is battery named CMOS on the motherboard, if this battery becomes dead PC loses its date and time settings. Problem in battery may result in this issue. Replacing the battery with a new one is the best solution to fix the problem.
Install Windows Update
Some of the Windows updates also contain a patch to fix clock keeps resetting. To download and install latest Windows updates follow the steps below:
  1. Click on Start and open Control Panel
  2. Locate and click on Windows Update
  3. In the right panel click on Check for Updates
  4. Install the Updates
  5. Restart your computer
Repair Windows Registry
Mostly PC problems occur due to corrupt Windows registry. To fix clock keeps resetting problem you are required to fix registry error. You will need a good System Utilities program that includes a Registry Cleaning feature. Registry Cleaner deeply scans registry problems and fixes them instantly.
To download System Utilities program including a Registry Cleaner click here.
Scan System for Viruses
Attack by viruses or spywares on PC may also results in this problem. To fix this issue you have to completely scan your system for malicious or infected applications and clean all the files detected by antivirus program.
Download Clock Keeps Resetting Fix Tool
Sony Vaio with Windows 7, same message at startup help
Are you able to log into your Account? If so download ccleaner and run registry cleaner. That might work
1helpful
2answers
Runtime Error! Program: C:/Program Files/Sony/VAIO Gate/VAIO Gate.exe This application has requested the runtime to terminate it in an unusual way. Please contact the applications support team for...
When I try to send e.mails Outlook Express I keep getting this message. Account`home`,Server,`IPAM`,Protocol SMTP. Port 25, Secure (SSL). No. Socket Error 11001, Error Number 0x800CC00D and cannot sent...
You need to check the setup of your mail account in Outlook Express. The most likely problem is that your server is a POP server, not a IPAM. var fctb_tool=null; function FCTB_Init_0471ebc3ace64d17bcd287c3b687bda5(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_3d5de3a63a7247db98aaf3bd066ea694(t) { fctb_tool=t; start(fctb_tool); }
Mensaje al cargar mi compu Vaio Sat Survey. exe has stopped working
The VAIO Sat Survey is an Application that loads at the Startup. If the Application in the Computer is corrupted, it will display an error message that the "VAIO Sat Survey has stopped working".
You can just remove the "VAIO Survey/VAIO Sat Survey" from the startup items to fix the error message.
Please follow the below steps to disable the Application from starting automatically and fix the error message.
  1. Open the run window by pressing the "Windows" and the "R" Keys.
  2. Then, in the run window, please type "msconfig".
  3. This will open the "System Configuration Utility" window.
  4. In the System Configuration Utility window, please click the "Startup" tab.
  5. In the startup tab, please scroll down to view the "VAIO Sar Survey/VAIO Survey.
  6. Then, please remove the check mark next to the above items.
  7. Then, please click the "Apply" and "OK" buttons.
  8. The Computer will prompt to restart.
  9. Please restart the Computer.
  10. The error message should not be there when you restart the Computer.
Vaio sat survey not working
PC's mouse is not functioning properly
http://www.sony.com/index.php
go to services and support and download the mouse drivers
2answers
How to get ride of the message ''Vaio Sat Survey.exe has stopped working''message onn my new VGN-NW120J
See this forum post. or this one.
You can uninstall the Vaio VSC Vaio survey program from the control panel>programs & features list. If you want to keep the survey program sony put on your system, but don't want it to run, remove it from the startup list.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Hi guys, I keep getting an error message that says: Stream reading error when I try to use the sony vaio recovery wizard. My computer is the sony vaio pcg-frv27 notebook. The first problem was that...
Try rebooting and hitting the F8 repeatedly as soon as the boot sequence starts. When it comes up to an options screen select repair. From there you can let windows try to repair or select to install to the factory settings.
3helpful
Vista vaio survey has stopped working
VAIO Update has been disabled. Start , all Programs, VAIO Update 3, VAIO Update Options , Reenable the checkboxes and you shouldn't get the message anymore. This program runs at startup to check for updates with SONY, pretty useless.
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
