Radio or DVD will not power up
SOURCE: does not play cd or dvd but will play radio
not true you need to but the optical cable that go from the av unit (brian) to the DVD
SOURCE: Radio Shack HDTV remote codes for a (15-135) That
radio shack HDTV remote..need codes for vizio
SOURCE: i need remote control codes for a Sylvania VCR/DVD
hi! i have here a couple of codes for your sylvania DVD/VCR just try them, 1027, 2064, 3105, 1124, 2078, 3088, 1296, 2213, 3147, 1145, 3095. hope this helps!!!! goodluck!!!
SOURCE: Radio won't play on my
How would someone on the internet know if a fuse was a
problem?
Check all your fuses
Not a fuse if you can see the channel you set it to
SOURCE: My 04 pacifica radio, heater, dvd won't play, no
Check your relays the accessory relay right hand upper corner and the run relay middle left side if they are the same relay switch them and see if that works if not could be the body control module. Realys under hood to the right of the battery
