20 Most Recent Sylvania DV220SL8 DVD Player/VCR Questions & Answers
i suggest you to buy a Maxell VP-100 VHS Dry Tape Video Head Cleaner, the head of the VCR is dirty that cause the tape get caught or stuck. hope this help you
Sylvania... | Answered on Oct 06, 2016
is it a commercial DVD or a home made DVD? For the DVD player itself, double check all of the cable connections and then check the input setting on your television.
Sylvania... | Answered on Aug 26, 2014
One simple solution is to unplug the unit for 30 seconds then plug it back in. Worked like a charm for me.
Sylvania... | Answered on Aug 23, 2014
Check its Ariel connections for firmness. If found OK, check and replace its tuner.
Sylvania... | Answered on Aug 08, 2013
Someone first will have to open the player to see if mechanism jammed or something out of position and to see what is actually happening--this is the flaw with combo units--one part fails to work and that can be the end of the unit.
Sylvania... | Answered on Oct 24, 2012
see the procedure and fix it.God bless you
    • 1 Purchase or borrow an imported DVD. The only real reason to make your DVD player region-free is if you plan on watching imported DVDs.
    • 2 Locate your DVD player's brand name and model number. These can usually be found on the box the DVD player came in, or on a sticker close to the video inputs or on the bottom of the DVD player.
    • 3 Have your remote handy. You will need your remote to enter the input codes into your DVD player.
    • 4 Locate a Web site that can help you with the codes you need for your particular DVD player, since all DVD players have different codes. Try DVD Exploder or Video Help (see Resources below). Both have an extensive list of codes for almost every kind of DVD player manufactured.
    • 5 Enter your brand name and model number when prompted to do so on the Web site. If your particular model number is not available, try searching under the brand name. Sometimes you will be able to find a model number that is close to your DVD player's model number.
    • 6 Enter the codes into your DVD player with your remote. Be sure the DVD player's door is open-almost all codes require the door to be open.
    • 7 Test your imported DVD to see if it works, once you have entered your code into the DVD player.
Sylvania... | Answered on Oct 02, 2012
If you are using a Sylvania DV220SL8 DVD Player \ VCR combo (which this question is posted under the heading of) there is a very simple reason why you can't format DVD-RW disks. DVD Players can't do that. You need a DVD Recorder to format DVD's.
This applies to all comments under this heading as well. You can not record if the unit you're using does not have that capability. And this unit does not have it. You can record with the VHS VCR, but the DVD Player is just that... A Player. It's not a Recorder.
Sylvania... | Answered on Oct 03, 2011
The instruction book will give a list of Error Messages and their meaning.
If you've lost the book go to Sylvania's website where there will be easy to follow steps to either viewing the book for the device or downloading and printing it.
Sylvania... | Answered on Sep 20, 2011
Hello there,
If your player does not have the usb port or hub on it,you will not be able to connect the mp3 player to the dvd player,but if it does have the port, that is where to connect the mp3 player.
There are some kind of devices that helps to connect the mp3 to the dvd through the audio plug in on the back of the player.
Hope this helped, Goodluck Elect_Comp
Sylvania... | Answered on Aug 10, 2011
This is typical with many sets when it goes old as there is a high possibility that the components over a period of heating and cooling, tend to bring on a problem of dry soldering. So my advice is to check the set for some loose joints that have played on to give you these erratic shut downs or poor performance.
The best way to check for loose connections is to tap lightly when the set is powered on , If there is change while tapping then it seems that there are DRY solder joints. Remove main plug, the covers - with caution of high voltage, check for dry joints, use a good soldering iron to solder all suspected points.
Sometimes the fault occurs when the set warms up, if so you can simulate the heat using a hair dryer on the suspected areas, try with the power supply, distribution, Processor controller, driver controllers on the A/V related sections. Also the use a FREEZE-IT spray can simulate the components to cool and show up the fault.
Based on the above method you must be able to locate the area of fault and solder the sections. Sometimes large IC's- ones with more pins- tend to have drying in some pins and so cause faults related to the IC's protocol. Have a rough idea of looking into the areas to reduce the time of probing. Check the power plug and the power socket for loose connection.
Sylvania... | Answered on Jul 07, 2011
Press the top menu button on the remote after putting a multi movie DVD. Scroll down on the movie file you want to play and press enter. You will see two items in each of the movie folder, Scroll down on the second item and press enter.That is the movie folder. It will play.
Sylvania... | Answered on Mar 08, 2011
recorded DVD-R should be finalize first in the recorder to make the DVD-R playable in your PC.
On the manual of your Sylvania recorder find the steps on finalizing the disc after completing the recording.
You also must have a DVD player software installed in your PC in order to play it. There is a limit format of files that a windows media player can play in windows. Suggested player is PowerDVD player that can be downloaded free in the internet.
Sylvania... | Answered on Mar 01, 2011
If you pc just plays dvds and is not a dvd burner theres and good chance that it just cant read that format and you would need and new dvd drive for your pc. sould be like $20 on amazon
Sylvania... | Answered on Feb 28, 2011
Sylvania DV220SL8 DVD Player/VCR Logo
63 questions posted
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sylvania Televison & Video
Most Popular Question
cannot figure out get play more
  • Televison & Video
