Shutter timing
First, I'm not a Nikon tech.
* Wow, old school. I had 3 nikkormats even the 1/2 frame one. Well I still got them but I use my phablet now.
* Sticky shutter usually means the camera needs cleaning and probably a spring replacement. The shutter is exposed every time the lens is taken off or the back is opened.
* Lots of stuff and dirt gets into the body. I've tried cleaning fluids but that's not a good idea if your using the wrong fluid or spray it in the wrong place.
* Here is a Forum that may address the issue; https://www.flickr.com/groups/18787520@N00/discuss/72157647706281597/
* You should take it to a camera shop (older one) to have it checked, cleaned, and lubricated.
Aloha, ukeboy57
SOURCE: How to Fix D50 Nikon flash shutter and light not working
please i want u 2 send me free digital camera
SOURCE: nikon d40
Take the lens off and continue pressing the shutter untill it doesn't react anymore, you should then have a normal menu without the error message.Put your lens on and you're all sorted.Cheaper and less hassle than sending it to Nikon.
olly
SOURCE: Nikon F3 w/MD4 motor drive...Not working!
Check to see if the manual shutter release (the one that is to the left of the lens when you look at the camera head on) is not cocked and ready. It should have its lever resting against the lens collar. Since this is the manual release of 1/80 second, this can sometimes be the cause of the problem. Also, make sure the shutter speed dial is set to something other than the 80 speed.
Since you can get a reading on the light meter, its likely not a power issue, plus the F3 is capabale of pulling power either from the drive or from the battery compartment.
Sometimes the electronic F3 shutter button can seize due to lack of exercise. The curtains won't need placing unless they are worn, but the switch may need replacing.
SOURCE: shutter speed on my nikon d80 is to slow
Try CUSTOM SETTINGS MENU 31. (turn off EXP. delay mode).
SOURCE: nikon f3 hp light meter wont work
I'm interested in this as well. Just installed fresh batteries, light meter says 1/80 in all shutter settings faster than 1/60 (otherwise it shows the correct setting).
Since 1/80 is the flash sync speed, it may be that the camera thinks there's a flash attached. But it is not...
Strange thing is that one time (I tried a couple of times today) the light meter worked correctly; it showed other timings and they changed as I turned the aperture ring...
