Maybe the tv main board problem,or the HDMI interface out of works
Abctay.com Wholesale tv parts,include TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc.
SOURCE: Help HDMI Splitter Doesn't Work!
The HDMI splitter is intended to take one source to two displays. You need an HDMI switch to take two sources to one display, a device you can tell which input to select.
SOURCE: Vizio gv42L working fine on cable hooked directly.
Reset to factory setting,should work,back to normal,not than ur backlight video board is dying shorting out.
SOURCE: is there a way to do hdmi output on my tv to an
A HDMI splitter enables you to display the same image on multiple monitors or TVs. The key is that signal needs to split at the source like DVD player, DVR, cable box etc. You can split the signal from a TV. If you are looking for quality HDMI Splitter products I would recommend checking KVMSwitchTech.
