Its a bush freeview B1TBHDPVR. I have tried disconnecting aeriel turning box off retuning and setting it up again but still this message appears.. if I press OK it goes off for a minute or two but pops up again... very annoying... any ideas please??
I have a bush unit as well with same problem
You must go into menu and access the timer
My model is different but if you can access the timer open it
You should see a list of all your programmes set up to be recorded
Delete all I listed programmes and set up your recordings again
This should solve your problem
I think there must be a glitch in the timer software
SOURCE: pop up box appears periodically
try bringing up the menu, and see if there's an option "factory default", and try that. you didn't mention what button on the remote you press to get rid of the popup, or what feature you are turning off to get rid of the popup,
SOURCE: Similar problem as you helped me solve before.
OK, I think I see the problem there.
The aerial lead from the DVDR to TV should be removed.
You should have it setup the same as the other Freeview - VCR - TV
Nutshell time:
Main aerial to Freeview input.
Loop aerial from freeview output to DVDR areial input (all this does is allow you to watch freeview, or standard both out of the DVDR)
So..
Scart from Freeview to DVDR input
Scart from DVDR output to TV
Set DVDR to AV input mode.
Set TV to AV (whatever number you need for that..you now won't get anything on screen unless you have the right input selected)
If you can now see the Freeview picture on the TV and change the channels with the Freeview remote then you should be set for recording.
Having the aerial and a scart lead both going to the TV is not needed.
SOURCE: Lost BBC channels on retune for digital Switchover - why?
I had the same problem,
you have to revert your freeview box to it origional factory settings, then rescan for channels.
hope this works.
SOURCE: Freeview has locked on one channel and won't retune
Used the solution of another user and it finally worked after a few attempts
SOURCE: remote control codes for freeview and dvd recorder
what is the code for a technika freeview box for a universal remote control
