There are several analog inputs. I'd choose the one that that says 'VCR (iPod'). With the preamp, any analog input should work. The preamp is basically needed for inverse RIAA equalization. LPs are equalized in order to keep the record grooves smaller, for longer playing time, Bass frequencies are reduced and treble increased, so they need an inverse filter, which the preamp supplies, as well as providing a signal level more suitable for the receiver input. Best Budget Phono Preamps For Your Turntable
SOURCE: Turntable to Receiver
Yes you will need a pre-amp to connect a turntable to this unit. For the AUX input you will need something that can output 400mV into 47k ohm, somewhere like RadioShack should have what you need. Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE: Connect Onkyo CP-1020F Turntable to Theater System?
Yes. It needs to have Line Level (slightly amplified or pre-amp'd) before your home theatre system can 'hear' it.
SOURCE: Denon AVR-790, no sound from Zone 2. Assigned amp
I re-did the connections and voila, it worked,
SOURCE: denon avr-790 sirius antenna antenna connection
The connection is similar to what is mentioned in the user manual bellow. Slightly different model but the connections are universally similar:
http://www.rotel.com/content/manuals_archived/rb850.pdf
Thank You
SOURCE: What inputs on the Denon AVR 1500 do I use for
If the turntable is old-school (not self-preamplified) just connect it to PHONO.
If the TT is self-preamplified use any available Line Level input, like AUX.
