SOURCE: False fish readings
False fish readings are commonly caused by electrical interference such as alternator noise, and by air bubbles flowing across transducer.
For starters make sure your fishfinder is on an independent circuit and not on one powered by your ignition switch. In other words, you should be able to turn your fishfinder on, even though the engine is turned off. Ideally the fishfinder should be wired directly to the battery with an in line fuse.
Try running the boat at a speed slightly higher than trolling speed, then kill the engine, as the boat slows down to trolling speed do you still see false echos? If yes then the problem probably lies with how the transducer is mounted, or where it is located on the hull.
If you don't see the false echos when the engine is off, it may be necessary to reroute the transducer cable to keep it away from the boat's ignition wires. You can get transducer extension cables if necessary. Also there are filters that you can buy that suppress alternator noise buy attaching between the battery and the engine.
Another common cause of false echos from electrical interference is a transducer cable that has been cut and spliced.
I hope this information helps. Please reply if you have any questions about my response.
SOURCE: Broken composit carbon shaft on
Lifetime gaurentee on the shaft, a dealer should be able to help you out
SOURCE: transducer is mounted on a
Are you utilizing another unit in your dash? If so, sometimes when both units are on and in sonar mode, their frequencies will intefere with each other causing the vertical lines. I would suggest turning your dash unit off or lowering it's Hertz rate from 200Hz down to 50Hz.
Funny story...I saw this same issue on my boat years ago. I had an X102C up fron and an LCX-19c in the dash. I acutally thought it was some sort of man-made structure and spent time fishing it...DOH!
SOURCE: lowrance x135 not functioning properly
Had the same issue with another brand. Turned out the transducer cable was picking up noise from other cables (power, trolling mtr. etc). Try moving the transducer cable away from any other cables. I put the cable in a 1/4 " plastic housing up to the point where it was above deck and it stopped all the strange stuff. Not sure about the temp issue??
SOURCE: my 570 transducer is mounted on trolling motor.
I too have the exact same problem. .6 to 6ft then stays at .6. love to figure this out.
