20 Most Recent Lowrance LMS 332c Mapping Sonar/GPS Receiver Questions & Answers
I have a lcx 110
I have found several units that have the same problem. All turned out to be a defective keypad. And almost all are specifically the power button. Not something Lowrance will repair. I've been purchasing some of these units for parts. If you still have it I might be interested. [email protected]
2/5/2012 4:11:33 PM • Lowrance LMS... • Answered on Feb 05, 2012
Hi,when i switch on my lms-332c the map does not
I am guessing that the card you are using is a NAVIONICS chart? There have been some Lowrance units that were made around the same time that have had problems recognizing a Navionics chart right from power up.
Make sure the LMS-332 has the latest firmware version which can be downloaded from http://www.lowrance.com/en/Products/Marine/Full-Size-SonarGPS-Chartplotter-Combos/LMS-332C/Downloads/LMS-332C-Software-Update/
If the update doesn't help, this is going to be a compatibility problem with the LMS-332 and that particular card. You will need to replace the card or upgrade to a newer unit...but probably can just get used to removing and replacing the card when you turn the unit on.
7/11/2009 7:37:48 PM • Lowrance LMS... • Answered on Jul 11, 2009
I have a lowrance lms332c
try to hold in the page button and power button at the same time to reboot your unit, But you may or may not lose waypoints,
4/7/2009 1:14:42 AM • Lowrance LMS... • Answered on Apr 07, 2009
I have a lowrance 522
I would verify that your "chart speed" is set to 100%.
Triton72
3/25/2009 4:52:59 PM • Lowrance LMS... • Answered on Mar 25, 2009
Transducer is mounted on a
Are you utilizing another unit in your dash? If so, sometimes when both units are on and in sonar mode, their frequencies will intefere with each other causing the vertical lines. I would suggest turning your dash unit off or lowering it's Hertz rate from 200Hz down to 50Hz.
Funny story...I saw this same issue on my boat years ago. I had an X102C up fron and an LCX-19c in the dash. I acutally thought it was some sort of man-made structure and spent time fishing it...DOH!
3/25/2009 4:48:06 PM • Lowrance LMS... • Answered on Mar 25, 2009
2answers
I have a Lowrance x 4 pro it won't power down with the switch this is the 2nd one I have bought
Greetings, Please consider returning the device to the manufacturer and purchasing a Garmin GPS from amazon, BestBuy, or Walmart. Garmin has been around for at least 1 decade and I believe has a more solid brand name than Lowrance. Thank you.
3/11/2023 5:59:51 AM • Lowrance GPS • Answered on Mar 11, 2023
2answers
Lowrance 5200c wont display Navionics map.
Hi, Please test the backup sd card on another GPS if possible to see if the zoomed-in section of the map file shows up or not. If it shows, then you'd need to send in your lowrance gps for repair from the water damage. Thank you.
11/11/2022 3:21:31 AM • Lowrance GPS • Answered on Nov 11, 2022
How can I replace the keys pad module on my lowrance globalmap 3500c
Only from the maker, or a somewhere like here https://www.sparesmarine.co.uk/webshop/electronics/globalmap-3500c/lowrance-globalmap-3500c-spares-accessories/?brandFilter=Lowrance%20GPS%20Chartplotter
Help & Support ' Fishing Electronics ' Lowrance USA ...
www.lowrance.com > help-and-support > guideTitle=Gl...
home. share. GlobalMap 3500C Unit and Accessories Information. language. mail_outline. link. GlobalMap 3500C ... 101-99. Flush Mount Kit. FM-5. 113-04.
2/10/2021 8:36:47 PM • Lowrance GPS • Answered on Feb 10, 2021
Need manual for lowrance hook2 7 triple shot
https://www.google.com search gives a number of manuals that may be what you are seeking. Example: ftp://software.lowrance.com/Documents/Hook2-Series_OM_EN_988-11760-001_w.pdf
9/24/2019 9:56:46 AM • Lowrance GPS • Answered on Sep 24, 2019
GPS Logo
17 questions posted
Top Lowrance GPS Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
ADMIN Eric
ADMIN Eric
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
View Most Popular
Lowrance GPS
  • Lowrance GPS
Most Popular Question
lowrance lms332c
  • GPS
