Alicia Smith Posted on Jun 19, 2018
Konica Minolta D7 is shutting down after taking a pic. tune off and then back on and she takes another pic.
5 Related Answers
Anonymous
  • 125 Answers
  • Posted on Jun 04, 2007
SOURCE: camera dropped, won't zoom in or out, won't take pics
I own a Z3. I had the same problem before. In my case I tried to pull and push the lens as I switch on or off the power. Ahter several attempts, the gear was aligned. I could actually hear the gear making funny noise. I never had another problem again. There are many Z3 owners who experience this problem and many of them tried different solutions. you can go to this forum to find out more about Z3's zoom problem : http://forums.steves-digicams.com/forums/view_topic.php?id=82303&forum_id=20
Anonymous
  • 67 Answers
  • Posted on Mar 30, 2009
SOURCE: Konica Minolta BizHub C451 printing red lines down documents
your imaging unit is damaged. call minolta guys to have a look it at and change it if neccessary
Anonymous
  • 6 Answers
  • Posted on Jun 19, 2009
SOURCE: won't take pictures
symptom 1: referred to as FFB (Firts Frame Black). this is when you do not use the camera for a while and when you attempt to take the first snap shot, the Shutter is either stuck, or takes a blank/black picture (some cases the picture came out bluish). Sometimes the camera would freeze and you would need to remove the battery and re-insert it in order to reset the camera. Usually the camera comes back to life and and is usuable for a while until you store it. Sony will fix this free as they identified it as a design flaw in which the remedied (incorrect gear size for the Shutter charge assembly). Contact Sony support as they own all Minolta camera assets and tell them you have the FFB or First Frame Black problem and they will set up a ticket and instructions on where and how to send it.
symptom 2: Camera does not respond at all to the shutter release. Focus is fine, menu works, every function works no problem except for the most important - taking a picture (releasing the shutter). When you first turn on the camera, you hear the Antishift module attempt to center the CCD with a series of clicking noise for 5 or so seconds (not a good sign, also called the death rattle). All 5 AS bars in the view finder are blinking. In this case, the Tebure Assembly (AS Module) has failed and will need replacing. This is not cheap - sending it in to Precision Camera will run you around $250-$280. You can do it yourself if you order the assembly from Sony: Item - ( TEBURE ASSY ), U3008233U, $118.22 ea. via 1-800-488-7669 (will take 3-4 weeks). And follow the service manual to install and calibrate it (via the service manual download at http://www.dyxum.com/dforum/topic36109_post396839.html#396839).
Anonymous
  • 5 Answers
  • Posted on Aug 10, 2009
SOURCE: After a power surge it comes up with a C0501 malfunction code and shuts itself down
Turn ON the Power Switch with the Stop key held down. This also works on bizhub 162
Anonymous
  • 53 Answers
  • Posted on Nov 07, 2009
SOURCE: my jvc hx-d7 radio is turned on in 2 seconds it
You can't. The main amplifier module will probably have a channel blown. The unit is detecting this and tripping into protect mode to stop further damage occurring. Needs to go to a repair place. sorry. ps If you get sound briefly before it trips off then it may just be a speaker wire shorting out! worth checking
Konica minolta magicolor 4750 e shutting off no code
might be the printer software or main board have a tech come out and look at it
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica minolta magicolor 4700e shutting off no code
have a tech come out might need the main board or software replaced
1helpful
Go to take a photo everything shuts down. and a err message comes up help.
Contact a Minolta representative. They're calling back the cameras with those symptoms and will exchange it for free until Dec. 31, 2010.
My Konica Minolta Dimage z5 won't play back photos. I get "system error' and the camera shuts off when I try & review photos
After calling Sony and doing all the things they said to do, that I had already done, they then said to send it in for repair to the tune of a minimum 175.00. So I had this brainstorm. I put the memory card back into my computer and formatted it from the computer. It worked for me, so try it, maybe it wil work for you.
I get a system error when i plug the cameral into usb/computer and try to download pics, camera actss like it will comply then promptly shuts down. takes great pics. all functions seem ok but downloading.
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Black Screen
are ur pics black if u see them on pc then
this is a BAD CCDproblem thousands are facing dont worry konica will do it free ofcharge even if u are out of warranty and not on list, just call orcontact KONICA see this PLS RATE ME FIXYAfor help
http://www.konicaminoltasupport.com/English.importantnotice_en.0.html
No display and picture
go for free repairs CCD failure pls rate me FIXYA for help
http://www.konicaminoltasupport.com/English.importantnotice_en.0.html?&L=0
1helpful
2answers
Cant download images
Its possible you might have to reformat the card in your Minolta Maxxum D7 to get the camera to recognize the card.
2answers
Camera dropped, won't zoom in or out, won't take pics
it has detected a mechanical restriction that is severe enough for the micro to "time-out" and shut down to prevent further damage.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
