Freezers Logo
P
P Hamilton Posted on Jun 14, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Just bought a bush bcf99l chest freezer. The red run (compressor) light has stayed on and the front of the freezer is quite hot to the touch is this normal?
Bill Boyd
Level 3:
Top Expert:
  • Bush Master 53,816 Answers
  • Posted on Jun 14, 2018
Bill Boyd
Bush Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11951169
Points
172802
Normal if it is the outside surface that is warm
as that is the condenser exchanging the heat through a panel
the compressor will run for a period until the heat inside the compartment is brought down
Experience has proved that to get any fridge /freezer to work well , place a bowel of water in first as that gives a heat source to cool down and it will do so more quickly that just an empty volume
Testimonial: "Thank you Bill. Its just that I was getting a little concerned as the inside is working as it should but the outside is more than warm to the touch in fact its very warm. There is now food inside there and has been for the last 5 hrs but hopefully this will settle down once its been running a little longer. Thanks again."
  • Bill Boyd Jun 14, 2018
    it would appear that the panel is the evaporator and monitor the temp by feel as it should cool down once the inside temp has been reached and the compressor switches off
  • P Hamilton
    P Hamilton Jun 14, 2018
    Thank you
5 Related Answers
Anonymous
  • 473 Answers
  • Posted on Oct 07, 2007
SOURCE: whirlpool 10cube chest freezer red light
yes.
Anonymous
  • 7 Answers
  • Posted on Jan 17, 2008
SOURCE: Defrost light stays on
Try advancing the defrost timer manually.
Anonymous
  • 363 Answers
  • Posted on Jul 28, 2009
SOURCE: Food in freezer is thawing, compressor very hot to the touch
It sounds like the motor to the circulating fan is wearing out . This fan is hard to diagnose as it will spin the blade , but as you said it will not spin fast enough to circulate air thru the freezer and refrigerator. The motor is DC non brush type. It will cost a minimum of $300.00 to repair/replace this fan assembly, but it is worth that compared to replacing the refrigerator
Anonymous
  • 4793 Answers
  • Posted on Apr 07, 2010
SOURCE: Red and Orange light staying on on my whirlpool chest freezer
try a total defrost,to clear any internal ice(every 12 months)then switch on and if you have a rapid freeze button leave on for 24 hours to get back to normal operating temp.if you have hard ice around the door seals then you have an air leak which you must sort out(try using a hot cloth to warm seals back into shape.....seals should fit all round, all the time.
Anonymous
  • 389 Answers
  • Posted on Apr 21, 2010
SOURCE: I have a Norfrost 100ltr chest freezer that is
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
I have a bush chest freezer CF-143GB. Recently the compressor runs continually. It can be stopped by turning the thermostat right down. A little while later and having reset the temp control it restar
Sounds like it has an auto shutoff if issues arise
Try clearing all vents - inside (make sure vents not covered) and out (vacuum - the coil areas)
Sep 11, 2014 • Freezers
Chest Freezer not wokring
Sounds more like a neutral fault if you have power there but no lights are working. Check each wire from the plug to the junction in the cabinet, then check to the lights and thermostat.
Unless you have a capacitance tester, you need to substitute a good capacitor in line to see if the compressor starts. If it was the capacitor at fault, the compressor would be trying to start every 5 mins or so and would be hot to the touch.
Jul 22, 2012 • Freezers
Not getting cold enough on the inside... the exterior too hot to touch.. why could this be?
Compressor relay could be fried. Feel the compressor. If it is too hot to touch then check your relay. The relays contacts could be welded together making bot windings stay powered up and overheating the compressor causing compressor shutdown on overload.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
RED TRIANGLE LIGHT STAYS ON CHEST FREEZER IS 10
defrost cycle is innactive, will ice up shortly and may not turn compressor off, defrost the unit totally(Turn off for 2 days with door open) and remove all water from the unit once done. Restart unit and should work normal for a week or so, ie...defrost cycle...get back to me if this is the case and will sort it from there, [email protected] Russ
My red light is on and the freezer is not making any sound and is not staying cold
The red light indicates temperature zone crucial. Listen for the sound of the compressor. If it's on and appears to be running, check the condenser to see if it is warm. If so, a faulty compressor may be the problem.
I have a Danby DCF520W Chest freezer. the compressor runs and the contents freeze but the outside case stays hot all the time. After a couple of days the freezer shuts down and has to be unplugged before...
your freezer may be overheating due to the defrost for the freezer door, (mullan heater) is staying on. Most likely the door is not sealing properly. Also if it has a power saver switch on the side select it to that.
1helpful
2answers
Chest freezer repair
I had the same problem with an upright and so I bought a piercing valve and charged the compressor with 134R and has been working great since.
Jul 05, 2009 • Freezers
Chest freezer
do you have voltage at the compressor? if not you have an open circuit or bad t-stat. if voltage is present and compressor is not running you have a bad start device or bad compessor. if voltage present and compressor runs you have a refrigeration issue get a new freezer.
Top Bush Freezers Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Bush Freezer Expert? Answer questions, earn points and help others
